Where is the evaporator temperature sensor connector?
Posted: Wed Aug 23, 2017 1:46 pm
by ihaveavibe
I want to check the operation of the evaporator temp sensor / thermistor but I'm not sure where to stick my ohm meter leads :)
Does anyone have a picture of where to test?
I'm guessing I'll have to disconnect the battery, disconnect the sensor, and test the resistance at the leads in some connector.
It should be about 2 kOhm and increase with decreasing temp (right?)
The reason I'm looking to test is that my a/c compressor doesn't ever seem to shut off. Even when I try to "freeze" the evaporator by recirculating and setting the blower fan to low. It's about 80-90F ambient now, so it's possible the evaporator never gets cold enough, but that's why I'd like to test. (Does anyone with a working A/C system notice the compressor turning off when the A/C is on?)
Thanks
Re: Where is the evaporator temperature sensor connector?
Posted: Thu Aug 24, 2017 10:09 am
Check out VASCO111's discovery in viewtopic.php?t=45973 and viewtopic.php?t=45989
Posted: Thu Aug 24, 2017 12:39 pm
by ihaveavibe
Yup, saw those threads (actually posted a question there too). I'll look again. Failed to find it the last time, that's why I asked if anyone has a pic :) I didn't want to yank things from the ECU.. I saw some connector thing that pig-tailed to the blend door actuator if I recall.
Posted: Fri Aug 25, 2017 5:00 am
Looked today and it's accessible by removing the glove box. Here's a pic showing the connector and resistor
This resistor is what should be wires to the thermistor
