Where do I find replacement power lock actuators?
Posted: Tue Aug 15, 2017 8:11 am
by milocat
I recently bought a 2009 Pontiac Vibe and it turns out that the front passenger and rear driver power door locks do not work. This is what happens:
- All doors locked. Press unlock button on key once. Driver door unlocks.
- Press unlock button again, rear passenger door and trunk both unlock.
- Press lock button. Driver door, rear passenger and trunk all lock.
The lock/unlock switch on the passenger door locks and unlocks the other door locks, but not its own lock. I have taken the door panel off and put a multi meter across the green and tan wires (to ground) and I can see a voltage pulse on both wires when locking/unlocking (I forget which wire is for lock and which is for unlock). This leads me to believe that the actuator mechanism is faulty. I have looked around and I cannot find a replacement anywhere.
So my questions are:
1. Can this be repaired? I tried to take the whole thing out but I couldn't get the bar from the external handle off.
2. Is it possible to find a replacement part anywhere?
Here is the plug I took off the actuator:
Actuator plug
Actuator plug
I tested across the green and tan wires shown here (to a bolt on the door):
Actuator wires
Actuator wires
This is what the rod looks like that attached to the top and prevents me from taking it out:
Rod attachment
Rod attachment
Here is what it looks like with the panel off:
Panel off
Panel off
The car is the FWD with standard trim, 2.4L I think.
I would really appreciate any advice!
Thanks.
Re: Where do I find replacement power lock actuators?
Posted: Tue Aug 15, 2017 10:14 am
by ehoff121
Does the passenger lock move at all when you hit the switch? I had a similar problem on a Toyota Highlander and had to replace the small motor inside the door lock actuator. They don't cost much compared to replacing the actuator unit and you pretty much did a lot of the work to get to the actuator already...
Do a google search for 'toyota door lock actuator motor' and you'll find lots of info on the motor, where to buy, and how to replace the $6 motor inside the actuator.
Posted: Wed Aug 16, 2017 10:57 am
by milocat
Hi,
No, the actuator does not move at all when I hit the switch. I'll take a look at your suggestion. Thanks.
