CAI/Short Ram Filter Maintenance
Posted: Mon Sep 01, 2003 12:30 pm
Ok, as the prime lecturer on using the search feature, I did in fact do a search, but wasn't able to find any info on this.I'm just under 2000 miles from my CAI filter maintenance. Does anyone know what exactly I have to do? I think I have to clean it and maybe oil it or something...Is there a kit I can buy? How does this process work...thanks y'all!
Re: CAI/Short Ram Filter Maintenance (ragingfish)
Posted: Mon Sep 01, 2003 12:42 pm
by philndz
yep...buy the k&n kit....
www.summitracing.com has it for $9.99
Re: CAI/Short Ram Filter Maintenance (philndz)
Posted: Mon Sep 01, 2003 12:52 pm
Even though I have an Injen filter?
Posted: Mon Sep 01, 2003 12:56 pm
by engine1
Its all the same, a degreaser and new oil! Any ones will work, although be aware the K&N kit has red oil(their filters are white when clean)
Re: CAI/Short Ram Filter Maintenance (silverawd26)
Posted: Mon Sep 01, 2003 1:22 pm
quote:You are suppose to clean it every 15,000 miles. I know...I'm 2000 miles away from the 15000 mile mark..
Posted: Mon Sep 01, 2003 2:23 pm
That's a good idea...what does a new filter run approximately?
Posted: Mon Sep 01, 2003 2:56 pm
Ok, maybe not.
Posted: Mon Sep 01, 2003 3:11 pm
by savedbyzero
Make sure you clean from the inside out. I say mileage doesn't matter. All conditions are different. Take it out at night, clean it, and let it sit. Reinstall in the morning. No need to buy another filter to swap in, unless your wife/girlfriend is pregnant and is about ready to pop! Then you might want to have the fastest vehicle ready for the delivery!
Posted: Mon Sep 01, 2003 9:56 pm
by Triton
That's a really good idea Rob. A second filter would be a good investment. I may have to do the same thing.
Re: CAI/Short Ram Filter Maintenance (Triton GT)
Posted: Mon Sep 01, 2003 10:13 pm
I would get a second filter, but I need to minimize my expenditures and reduce any non-crucial spending...
Posted: Mon Sep 01, 2003 11:27 pm
by goodvibe
Took my K&N out of the box and put it right into the air box. Big mistake. Had to clean my MAF. Works great now but I have a spare Wix filter to put in during the K&N cleaning. When I asked the local part stores about these filters releasing oil, not one of them ever heard of it before and some of the guys used the K&N in their rides. Bad (removed) dynos I guess.
Posted: Tue Sep 02, 2003 1:15 pm
by Lancer
I was checking out nitrous products and found this by ZEX. I think it's something I'm gonna get after the thrill of the S/C wares down a little.
Re: CAI/Short Ram Filter Maintenance (goodvibe)
Posted: Tue Sep 02, 2003 8:58 pm
by Kissfan79
Why was just dropping the K&N in a mistake? What caused you to have to clean your MAF sensor (and...BTW...how did you go about doing that being as I am about to purchase mine?).Jim
Re: CAI/Short Ram Filter Maintenance (Kissfan79)
Posted: Tue Sep 02, 2003 9:40 pm
by goodvibe
It comes sealed in plastic and a bit too wet with oil. Thats why it's good to let them sit and get tackier. I knew about this but thought a new filter would be OK. Air flowing turough the filter carries oil droplets onto the MAF. Car runs lean and makes less power until you clean it. Not good for anything but mileage. If your getting better mileage after a CAI, you may also be making less power until you clean the MAF. I used carb/choke cleaner and a gentle wipe.
Posted: Wed Sep 03, 2003 4:05 am
by Kissfan79
Cool...thanks for the info. How long do you think it needs to sit before use?Jim
Posted: Wed Sep 03, 2003 4:07 am
by drunkenmaxx
not to sound like a moron, but what is the MAF??
Re: CAI/Short Ram Filter Maintenance (drunkenvibe)
Posted: Wed Sep 03, 2003 4:15 am
mass airflow sensor...
Posted: Fri Sep 05, 2003 3:50 pm
Ok...so this is what I bought: Now my question is -- I'm unsure if Injen uses proprietary oils in their filters...so not meaning to be a stupid question, but can I use a K&N kit on an Injen filter? When it comes to filters, is brand irrelevant?
Posted: Wed Nov 12, 2003 12:21 pm
by threekrows
Someone at a class I took told me to use electronic parts cleaner to clean the MAF, and it blasts out of the can hard enough you don't have to touch it with anything else.I think it was because some carb cleaners leave some residue,whereas the electronic parts cleaner isn't supposed to
Posted: Fri Nov 14, 2003 4:09 am
by robdog
All the K&n filters come preoiled from them, no need to oil when you first buy it.
Re: CAI/Short Ram Filter Maintenance (robdog)
Posted: Fri Nov 14, 2003 4:18 am
by drunkenmaxx
they all come pre-oiled i'm pretty sure, they are discussing after you clean your filteri am almost to 10k miles on mine, is it much of a pain?
Posted: Fri Nov 14, 2003 9:23 am
by MadBill
It can't hurt to service too often, but the K & N was designed to eat thousands of miles worth of dust in desert racing, and depending on individual driving conditions, it could be good for 50,000 or more without service on paved dust-free roads. Might be worthwhile inspecting it closely before deciding on a service interval.
