03 Vibe throttle body cleaning
Posted: Tue Jun 20, 2017 8:50 am
by JustinoBambino
Can someone explain how to remove/disconnect the throttle cable from the throttle body on a 2003 Vibe with the base engine? The videos and instructions I have found are for newer models that don't have the cable. That is the step that I am stuck on before cleaning the throttle body.
Thanks,
Justin
Re: 03 Vibe throttle body cleaning
Posted: Wed Jun 21, 2017 7:55 am
by ehoff121
Welcome to genvibe!
If you need to disconnect the cable, there's a pin at the end of the cable that goes in a round slot on the cam. Rotate the cam and you can slide the pin off of the cam. Don't forget the IACV while you have the TB off...
Images borrowed from Toyota Nation:
Link to entire thread, including IACV and intake manifold gasket replacement:
http://www.toyotanation.com/forum/132-c ... skets.html
