ABS Relay question
Posted: Thu Jun 01, 2017 6:58 am
by KingKrab65
I was in the fuse box under the hood yesterday in my 2003 Vibe. I noticed that the two positions that are supposed to have relays for the ABS brakes do not have relays in either position. The brakes still work great. I am guessing that the previous owner had pulled them for a particular reason, maybe a dash light was on.
I guess my question is if it will be detrimental to me or the Vibe to continue to drive around without these relays in place?
Re: ABS Relay question
Posted: Fri Jun 02, 2017 6:29 am
by ehoff121
Do you have ABS? Not all 1st gen FWD vibes do...
Posted: Fri Jun 02, 2017 12:25 pm
by KingKrab65
I found this:
"The 2003 Vibe comes standard with dual front airbags and daytime running lights, but ABS brakes are only offered on the AWD and GT."
So, that would mean that I do not have ABS on my base version. Thank you ehoff121, for the heads up.
Posted: Sat Jun 03, 2017 7:26 pm
by ehoff121
You're welcome!
You can confirm this by the absence of several 1/4" steel tubes running from the master brake cylinder, along the firewall, and over the right front tire. If you had ABS, the ABS unit would be just behind the headlight.
Here is a very nice 2003 AWD engine bay pic from one of our members, tnpartsguy. Notice the gray ABS lines running in front of the strut tower behind the power steering fluid reservoir on the left.
