2010 Pontiac Vibe Base 1.8 no power, no start
Posted: Thu May 25, 2017 5:10 am
by pakong
Anyone have any ideas before I take this into the shop? I have no power whatsoever and it won't jump start either. Fresh battery and new alternator. not even the door lights will come on.
Re: 2010 Pontiac Vibe Base 1.8 no power, no start
Posted: Thu May 25, 2017 11:21 am
by jolt
Battery terminals hooked up wrong? Bad cables and/or bad ground? Bad connections? Blown fuses? Blown fuses are the result of a problem and are not the problem to begin with, so if you have blown fuses, you need to find why the fuses blew.
Posted: Thu May 25, 2017 5:57 pm
by Zimm
test for a bad main ground cable between the negative terminal of the battery and the frame. to do this, put a jumper cable on the negative terminal of the battery. put the other end on the engine block. if it starts up, you have a bad main ground cable. fwiw, i have a 2010 with a 1.8 and mine went bad. was reattached once, then replaced the 2nd time. no issues since.
Posted: Mon May 29, 2017 11:16 am
by pakong
Thanks Zimm,
I will give that a try.
Posted: Mon Jun 05, 2017 2:09 am
by pakong
This was a grounding issue and is now fixes.
Posted: Sun Jun 11, 2017 9:10 pm
by jake75
Just when you fear the worst - a relatively simple grounding issue. Whew!!
Posted: Tue Jun 13, 2017 8:31 am
pakong wrote:This was a grounding issue and is now fixes.
Thus the old saying when I was in Diesel Technology college some 35 years ago " 90% of all electrical problems are due to faulty grounds"
I still remember this and apply it always when troubleshooting electrical work.
Posted: Tue Jun 13, 2017 9:20 pm
by jolt
You can never have to many grounds.
Posted: Wed Jun 14, 2017 10:42 am
by pakong
I'm switching the grounds to Zero gauge. One is already done. I'll do te other 2 on the weekend.
