deleted
Posted: Sat May 20, 2017 7:14 pm
by indeebidably
deleted
Re: I've got ticks! (What's that engine ticking noise?)
Posted: Sat May 20, 2017 10:33 pm
by jolt
Back of the engine, one guess is a small exhaust leak which may be between, the head and the exhaust manifold, cracked exhaust manifold, or where the pipe goes on the exhaust manifold. Another guess is spark jumping from a coil pack but you should be getting a "Check Engine" light with that. Then another guess is the valve clearance is to much, when was the last time you checked the clearance?
Does the ticking change when the engine is cold or hot? What about if the engine is under load, does the ticking change for how load it is?
Posted: Sun May 21, 2017 3:35 pm
by Derf
Its hard to distinguish the sound. The sound is loudest over driver rear side of the engine, the PCV valve is located under the engine cover on the drivers side. It can make a fast clicking sound heard in the video, but that would be the loudest PCV valve I have ever heard. Sounds more like electrical arcing. Pulling off the plastic engine cover will give give you better idea what is going on.
