specs for stock door speakers? base model 2007 base radio
Posted: Sun Apr 30, 2017 5:18 am
by roleo71
I am upgrading my stock GM stereo receiver(burned out display) to a JVC unit which has an output of 50w rms x 4. Just wondering if anyone knows the specs of the stock door speakers in terms of power range, frequency response, sensitivity, etc.? I'd rather not have to swap out the speakers at this time so I'm hoping the stock ones will sound ok with the new stereo until I get around to doing a speaker upgrade in the future.
Re: specs for stock door speakers? base model 2007 base radio
Posted: Sun Apr 30, 2017 9:56 am
by jayoldschool
They'll be "ok" if you keep the volume down. They're 2ohm, btw. However, even the cheapest Pioneer set from Canadian Tire or WalMart will be WAAYYY better than the stock paper cone units. You can order mounting rings, make your own from plywood/MDF/whatever, or do what I did: cut apart the old speaker to use the housing as a mounting ring for the new speakers.
Posted: Sun Apr 30, 2017 1:16 pm
by MacGyver
The stock speakers will be fine, as long as you set the highpass frequency to 125 Hz, so you don't try to make the stock speakers reproduce low bass they were never designed to do.
Posted: Sun Apr 30, 2017 5:22 pm
by roleo71
Thanks for the replies. I'm new to this forum and just realized that I should have posted my question under the audio section.
