'09 random engine shut off
Posted: Thu Apr 06, 2017 11:01 am
Hi GenVibe,
My '09 Vibe's engine base model 2wd 1.8L has shut off three times in the past few months whilst going downhill and around sharp curves that you have to take at about 25-30 mph. Once I pulled over safely, the engine started and ran normal.
Has anyone had this trouble or know a possible fix? I did find this but only applies thru the 2008 model year:
The recall affects no less than 161,754 units of the Pontiac vehicles manufactured between 2005-2008, all equipped with the 1ZZ-FE engine and in two-wheel drive configuration. The problem is a manufacturing defect of the ECM (Engine Control Module).
