nasty P0171 code
Posted: Sat Apr 01, 2017 5:08 am
The car is an 2007 base Vibe 2WD. I'd posted about an intake earlier in the month of March. Doesn't sound likely that swapping one would work. I will revisit the intake gasket since my shop didn't use the OEM Toyota gasket.
All the work done to the car has been by me (limited), or one of my two friends who have considerable knowledge and abilities and who each own repair shops.
nothing, and I mean NOTHING has worked to clear the cel code P0171.
here's what has been done:
MAF sensor (twice- just to rule of a defective part)
pcv value and hoses
intake gasket (not oem)
system was hooked up to smog machine with no leaks detected so we tried the Front O2 sensor
most recently in the month of March
fuel pump ( scanner showed some goofy readings when cranking so we thought perhaps the Fuel pump was erratic)
rear O2 sensor
computer under the glove box was one serial number off the list on numbers in a TSB for bad computers so we bought and flashed a new computer
I'd tried Techtron fuel injector cleaner but didn't know how long it would take to dissolve what was there so 4 new fuel injectors went in yesterday.
NOTHING has made an impact on the return of the P0171 code.
The state inspection sticker ran out yesterday, so I'm totally frustrated by this code and can't believe that nothing has worked as yet.
Car seems to run fine no matter what, the only thing that appears off is that sometimes there's extended cranking when starting the car. (another thing that made us think it may have been a fuel pump/fuel pressure issue)
The exhaust system has been looked over but nothing really stands out as a possible leak, but since i live near Syracuse NY (aka Salt City USA- a moniker earned by the history of being a salt producer in the 1800's, but one that very effectively describes the road maintenance program & how we make it through the lake effect snows each winter) corrosion of any metal parts can't be ruled out 100% visually.
Open to suggestions, cause I'm basically up Schitt's Creek , and I think my paddle just floated away,,,,,,,,,,
pcv value and hoses
rear O2 sensor
