JVC HU has Steering Control Wire in Harnes, Where to connect?
Posted: Fri Mar 17, 2017 11:57 pm
by MrC
I pulled out the factory HU of my 2009 Vibe(mp3 version) for a JVC aftermarket that has USB and Bluetooth. The JVC said Steering Control ready on the box and its harness has a single wire labeled steering control. Which wire on the factory harness should this go to?
Re: JVC HU has Steering Control Wire in Harnes, Where to connect?
Posted: Thu Mar 23, 2017 12:17 pm
by 302LVR
I'm not 100% positive but that feature may only work with an aftermarket steering wheel control. If u want go on websites such as crutchfield, sonic electronix, metra, or scosche.com and see if they offer any technical info on wiring it up. Hope that helps.
Posted: Thu Mar 23, 2017 5:16 pm
by ColonelPanic
Doesn't look like you can just connect the wire to something on the car's harness. I'm not familiar at all with the 2nd gen, but a quick check on Crutchfield indicates you will need an adapter to integrate the new radio with the steering wheel controls.
I've only set up one of these things once (for a co-worker with an older Altima) and it was a tedious ordeal but it did eventually work.
Posted: Fri Mar 24, 2017 8:55 am
by MrC
^Yeah, searching around seems to point at an $50 adapter though I'm feeling the true issue is lack of knowledge. Maybe in the future, after a few guys figure it out, it will be common knowledge on the web but for now looks like I'm screwed - pay $50 for steering adapter for a $60 HU.
The thing that gets me is its only one wire. JVC is not a stupid company. It must only require one wire or be the norm to only use one wire.
Posted: Fri Mar 24, 2017 7:15 pm
by 302LVR
You can always try the old school way and check the pins on the oem radio harness to see if you find a signal coming from the swc(steering wheel control). Being that u say it only uses 2 wires i can imagine one is + n the other -(ground) but i doubt only one signal wire will control volume, changing stations, etc. It's always worth a shot though n u may save yourself those $50. Good luck n let us know what you find out.
Posted: Sun Apr 02, 2017 10:11 pm
by MrC
Looked at the Crutchfield page and the adaptor does connect to a single wire.
Compatible Aftermarket Head Units: The PAC SWI-RC Steering Wheel Control Interface is compatible with the following steering wheel remote ready aftermarket head units.
Alpine, Clarion, Dual, Jensen Pioneer, Sony, and Valor: The aftermarket head unit must be equipped with a 3.5mm steering wheel input jack.
JVC & Kenwood: The aftermarket head unit must be equipped with a blue/yellow steering wheel input wire. (Not compatible with Kenwood KDC-BT318U, KDC-BT558U, KDC-BT562U, KDC-BT758HD, KDC-X598, KDC-X798, KMR-D558BT, or KMR-D562BT.)
https://www.crutchfield.com/p_541SWIRC/ ... ml?tp=3405
This is so weird! One wire, why do we even need an adapter?
