tail light?
Posted: Sun Feb 19, 2017 2:09 pm
by nugentc
This is a very "dumb question," I admit. On the 2003 Vibe tail light assembly, what is the 3rd (bottom) red section for? Is it ever supposed to light up? The top red section is the brake light, and middle amber sections are the turn signals. This 3rd section doesn't seem to have a bulb in it. The white circular light in the back bumper seems to be a back-up light. Everything lights up except for that bottom red section in the tail light assembly. What's it there for?
Also, can you get pulled over for a bulb being out (cracked assembly) in the white circular light in the front bumper? Is this a fog light?
Re: tail light?
Posted: Sun Feb 19, 2017 6:15 pm
by ColonelPanic
The bottom section of the tail light does not light up... It has no bulb, just a reflector.
Re: tail light?
Posted: Sun Feb 19, 2017 6:35 pm
by nugentc
Thank you, ColonelPanic!
Anybody ever been pulled over for a front fog light being out? I would need a whole new assembly here and am hoping to not spend money on that right now. But also, a new assembly is probably cheaper than a ticket, so I'm not sure which way to go.
Re: tail light?
Posted: Sun Feb 19, 2017 7:51 pm
by MacGyver
Just shut off the fog light switch, nobody will notice. And fog lights aren't required equipment. If you are concerned the police in your area are going to harass you for a front fog light, then let me know where that is, so I can avoid it.
Re: tail light?
Posted: Sun Feb 19, 2017 11:12 pm
by petervivian
A lot of base model cars don't even come equipped with fog lights. I will just use some tape to prevent the water from getting into the socket.
Re: tail light?
Posted: Mon Feb 20, 2017 6:17 pm
by nugentc
Good points! Thanks, everyone!
