Tight fitting brake pads
Posted: Wed Feb 15, 2017 11:28 am
I am changing the front break pads on 2007 FWD and the brake pads were on so tight I had to remove the claliper bracket so I could knock the pads out with a rubber mallet. I assumed that the pads were tight because of all the rust/corrosion on the pad retaining shim.
However, the new pads I got came with new pad retaining shims but after cleaning the caliper bracket and installing them it appears that break pads are still a really tight fit. I've done a lot of break pad replacements over the years and I have not noticed any being this tight.
As far as I ca tell there is no damage to the caliper bracket. I also measured the new pads and they the same size as the old ones. Can anyone tell me what the measurement between the pad retainer slots on the caliper bracket should be without the shims? Does this tightness seem normal for Vibe front brake pads or am I missing something?
Thanks!
Thanks!
