Cigarettes wiring
Posted: Wed Feb 01, 2017 8:01 pm
by Jobs
Anyone know how much power is supplied through the cigarette liter wiring harness. I want to install a 12v outlet if it has enough power
Re: Cigarettes wiring
Posted: Thu Feb 02, 2017 8:59 am
by gtv237
I don't think vibes had cigarette lighters? Either way the outlet is a 12v outlet. Capable of roughly 120 watts/10 amps.
Posted: Thu Feb 02, 2017 7:00 pm
by Jobs
Well I looked up a center console blowup and is says there is supposed to be a cigarette setup there besides the 12v and 115w plug up top.
Posted: Fri Feb 03, 2017 3:10 pm
by ColonelPanic
gtv237 wrote:I don't think vibes had cigarette lighters?
The first gens could have either a 12V accessory power outlet w/ flip-down cover or if the "smoker's package" was specified that was replaced with a cigarette lighter socket and element. And a small ashtray that sat in the cup holder.
The console 12V accessory power outlet was standard in the 2003-2004 model years but was eliminated starting in 2005.
Here is a how-to for adding the console power outlet in a 2005-2008. viewtopic.php?t=10792
Posted: Mon Feb 13, 2017 11:08 am
I saw in another thread that you have an 07. If that's so, then you should have a 115V AC outlet and a 12V outlet in the dash by the shifter, and, as ColonelPanic said, your Vibe would not have come with the 12V outlet inside the console between the seats, but its easy enough to add one there.
The 12V outlet by the shifter, whether its a cig lighter or just a 12V outlet gets its power from the 15A CIG fuse. This fuse is in the under dash fuse block, and also provides power to the radio. Those fuses are a pain to replace due to the awkward location of the fuse block
The wiring for the console 12V outlet gets its power from the 15A PPOINT fuse, which is also in the under dash fuse block
You asked if it had enough power, that depends on what you want to plug in to it,.
