				HID install with DRL & ALC removal
				Posted: Tue Jan 10, 2017 11:15 pm
				by 302LVR
				Hello. I'm new here so was wondering if anybody could direct me to another link or has any info on de-activating my DRLs(daytime running lights) or ALC(automatic light control) before i install my bi-xenon HID kit on my 03' VGT. I'm assuming i have to remove or disconnect these in order for my HIDs to work properly since i know the low beam headlights work at a percentage less than 100 when the DRLs are ON and i believe this might damage my ballast but i'm not 100% sure.
The other day i crawled underneath the driver side to access the fuse block and removed the fuse for DRLs but noticed that my lights still turn on automatically with low light environment and when i drop the e-brake. If anyone has done this or has any pointers i'd appreciate the help and feedback. Thanks.
				Re: HID install with DRL & ALC removal
				Posted: Thu Jan 12, 2017 4:47 pm
				by ImUrOBGYN
				I cut one single wire and it gave me back full manual control of my lights. I will have to take a look under there to see which one it was as I want to be sure since it's been a bit.  I kept seeing different crap, some of it complicated, online so I took it upon myself and took a look at the wiring diagrams. I'll try to remember to check tomorrow. Maybe someone else will chime in by then.
				Posted: Thu Jan 12, 2017 10:34 pm
				by 302LVR
				Sounds good. Any help would be greatly appreciated and yes i know figuring these things out sometimes can be a bit complex. I actually did something similar on my 03' Pathfinder when i ran the oem fogs on an independent switch but still using the factory wiring. Thanks once again.
				Posted: Sun Jan 15, 2017 10:29 pm
				by 302LVR
				Any updates???
				Posted: Wed Jan 18, 2017 9:49 am
				by ImUrOBGYN
				Sorry, slipped my damn mind. Between the weather here and both my Supra and RAV currently in the garage, I haven't looked. I'm going to pull the VIbe into the garage tomorrow for an oil change. I'll try to remember then.  I'm a pretty tall and big guy, so I almost gotta grease up to fit under that dash. lol
It appears you found an old thread on here concerning the red wire. I believe that's the one I cut, too. However, I do not have mine setup to run the fogs with the parking lights. I simply cut the one wire (I believe the same one they speak of in that other thread) and then taped the ends for safety.  Again, I'll try to double check tomorrow just for assurance.
				Posted: Wed Jan 18, 2017 7:26 pm
				by 302LVR
				Yes, luckily it seems i found another thread where they explain on how to do this along with other options as well as far as independent control of the fog lights. It's a big help IMO since i feel safer having the maximum amount of lighting in dark areas since these cars are pretty small as well. Thanks for your help though and i'm looking forward to doing this very soon.
				Posted: Wed Jan 18, 2017 7:41 pm
				by 302LVR
				Btw, here's a link provided by Vibenvy which explains the independent wiring of the fog lights for anyone else who might be interested. Big thanks!
viewtopic.php?t=9844
				Posted: Wed Feb 01, 2017 11:15 am
				by 302LVR
				Here's the link someone else shared to help with the DRL bypass in case someone else is interested in doing it. It's a big help and mandatory i believe when installing HIDs since they won't work off a lower power percentage like the DRLs produce, it's either ON or OFF. Hope it helps others. Thanks once more.
viewtopic.php?f=18&t=28390&start=50
