No fog lights, but I have checked the obvious things
Posted: Tue Nov 22, 2016 9:10 am
by Toddman214
Hi all. New member here.
I have a 2006 Vibe, that the fog lights both stopped working. I can't tell you if they stopped working at the same time, but that is my suspicion, due to what I have tried. Here is what I have done/checked so far.
- Both bulbs replaced
- Checked fog light switch. The fog light dash led does turn on, so the switch works.
- Checked the fuse, and it is not blown, but still tried a known working 15a fuse.
- Checked relay by swapping with horn relay, which is the same.
Anything else I can check that could be an issue, and easily accessible. Not sure I'd be able to trace the wires around.
Thanks all.
Todd
Re: No fog lights, but I have checked the obvious things
Posted: Tue Nov 22, 2016 6:24 pm
by MacGyver
Are you getting power at the light sockets? Use a multimeter, and keep tracing back. Sounds like a wire got cut or chewed between the relay and the lamps.
Posted: Wed Jan 11, 2017 2:09 pm
by 302LVR
This may sound dumb but just adding some feedback since i recently had the same issue on one of my vehicles. Even after adding a new relay try wiggling it around or making sure the female connectors are tight enough to make contact as sometimes they don't. U might be able to close them up a bit just in case it's a bad contact. Also, make sure your headlights aren't in the HIGH beam position. Other then that, the only thing i can suggest is checking your wires with a multi-meter like suggested above especially for proper ground if u see any corrosion on the body or any ground connections. Hope that helps.
