2ZR-FE Water Pump
Posted: Thu Nov 17, 2016 8:58 am
I made the mistake of replacing mine as preventative maintenance. Since then I've had nothing but problems. The first few times the seal started to leak. I replaced it with one from Toyota and it hasn't leaked since but now the bearing went out on the pump. This thing is less than a year old with roughly 7,000 miles. I even used a krikit gauge to tension the belt to spec so I know it wasn't too tight. Should I go back to the original sheet metal design? Are the aluminum ones just trouble or what?
