Had the pleasure of replacing the cig lighter fuse....!
Posted: Mon Nov 14, 2016 11:53 am
by gginnj
Well, my theory is that Toyota expects only very short thin contortionists will be driving vibes - why else would they put that fuse box where it's at???
Well, for what it's worth, the fuse puller that is in the fuse box in the engine compartment really is the best puller for those fuses
as you can push it onto the fuse fairly easily and pull it out. works better than the fuse puller that comes with the pack of fuses.
Now for some ibuprofen.....
Re: Had the pleasure of replacing the cig lighter fuse....!
Posted: Mon Nov 14, 2016 12:50 pm
by BenWA
In old 70s-90s Dodge vans, the fuse panel is under the glove box door, which up on top of the dash. It couldn't be any easier.
http://www.realityoneradio.com/ztek/stu ... OVEBOX.JPG
Posted: Fri Nov 18, 2016 10:26 am
My cig lighter can short out fairly easily, so I've replaced that fuse a number of times. I use a mirror, a flashlight and a long latching surgical forceps,
- 4cep.jpg (10.02 KiB) Viewed 3941 times
can change the fuse kneeling on the ground by the open driver door, no contortionist skills required
Posted: Fri Nov 18, 2016 11:55 am
by gginnj
yeah, I thought about trying the mirror/flashlight method next time as well - will have to look into getting some long nose locking forceps.
That would require leaving the fuse block cover off as well - but I guess with a little manipulation, you could unlock that as well with the forceps.
Thanks
Posted: Wed Nov 23, 2016 11:20 am
Good point. I havent had the cover on the under dash fuse block for probably 12 years
