strange starting issue
Posted: Wed Nov 02, 2016 1:02 pm
by shredhead
couldnt find exact issue im having in the search hope someone has an idea....
this seems to happen more if the car hasn't ran for several hours, for example first start in the morning...or after i been at work all day and start it to go home. if i am running errands off/on all day it will start normal 90% of the time
here is what it is doing
it will try to turn over for about 1 sec then i hear a spinning type noise...i can try it about 5 or 6 times and it does the same thing...then about the 7th try it start up
at first i thought it was a loose neg ground clamp, the one on the battery, i couldn't get it any tighter and it was loose....so i bought a new clamp but still same thing
any idea help would be great
thanks in advance :)
2007 vibe
Re: strange starting issue
Posted: Wed Nov 02, 2016 1:18 pm
by Caretaker
Does it make a metallic screeching noise when it does start? A noise that sounds like a loose heat shield rattling very fast and loud? If so, it is the bendix gear inside your starter and it is time for a new Denso starter. Mine got worse over time and was especially noticeable when it began to get cold outside and when the car had not been started for awhile (ie: like overnight).
Posted: Wed Nov 02, 2016 1:27 pm
by shredhead
hmmm i didn't notice but i will try and pay more attention to that and post back....ty
Posted: Wed Nov 02, 2016 4:06 pm
by Caretaker
Here's a better way of identifying the noise I refer to: does it sound like the grinding noise you hear when a car is already running, yet you turn the key to start the car not knowing it is already running? That is the metallic grinding noise which indicates the bendix gear is failing inside the starter and it soon will be time for a new one. Again, most people who have experienced the failing bendix gear on the Vibe and Corolla have the noise happen over many months, usually when the cold weather sets in.
Posted: Fri Nov 04, 2016 5:37 am
by shredhead
hello,
no i do not hear any noise at all after it starts it sounds normal. it is just so weird, took several time to start this morning, i got to work, turned it off and tried to restart just to see, and it start right up perfect...grrr... jsut seems like the longer it sits the more it does it
i had an idea tho...
do you think something is getting wet overnight from the humidity..i live in houston area and the entire car is super wet in the morning, and the grass very very wet if you walk across it your shoes would be soaked...just to give you an idea.
Posted: Fri Nov 04, 2016 10:52 am
by Caretaker
It sure could be. I have had (twice a year) issues with my Vibe starting during very heavy humidity/dew/rain mornings where the car will sputter to a start. I don't know why it has done this; I figure it has something to do with the cheap bundling of wires (not individually wrapped and segregated) which triggers an electrical issue. I have new spark plugs in my car now, but have yet to change my ignition coils. Sorry I can't be more helpful.
by jolt
You make it sound like your starter drive is bad. Replace the starter.
