19's on a 2008 Vibe, fitting questions help
Posted: Fri Oct 28, 2016 6:39 am
by Fatpaul
see below
Re: 19's on a 2008 Vibe, fitting questions help
Posted: Sat Oct 29, 2016 4:11 pm
by Jbenrod
I don't know how it would work but think it's too extreme and would just spend the money on a good set of tires or some other interior mod.
Posted: Sun Oct 30, 2016 10:59 am
by NYfan08
Really depends on the offset. But I would say with an 8" width it would be pretty close, but then add the thickness of the adapters and I would think it wouldn't work. Like Jbenrod said just spend the money on a set of wheels that will fit without modification or adapters. There are plenty out there. I have 18"x7" on mine, and they fit well, but I also have a 40 series tire. General rule is you want to have the same circumference as the stock setup, so the bigger the wheel the lower the profile of the tires.
Posted: Thu Nov 03, 2016 2:16 pm
by Fatpaul
Ok going a different route, what do y'all think of these? Fitment issues?
Posted: Fri Nov 04, 2016 4:23 pm
by Owim
I can't see the pictures, and the links aren't working for me either.
Posted: Wed Mar 01, 2017 1:30 pm
by melriv
I got 18"s on my 2008 with 245/40's and the ride is definitely rougher however handles much better. I was told the 19"s are a much more expensive tire and also, that lower profile would be even rougher.
