Installed a K+N typhoon on 08 Vibe, throwing codes and not happy. HELP
Posted: Mon Oct 24, 2016 7:49 am
by Fatpaul
I installed a K+N typhoon intake on my stock base model 08 Vibe 5 speed, only mods are some nice spark plugs to the motor.
I'm feeling it gasping for air in the 3400 to 5000 range. The pickup is great but it's starts to break up when floored. I cleaned the air filter and wondering if I could have possibly "caked" it with too much oil?
Any ideas of why it's stuttering when under full throttle?
Also it just threw a code, going to look into this later today.
Re: Installed a K+N typhoon on 08 Vibe, gasping for air?
Posted: Mon Oct 24, 2016 8:39 am
by ImUrOBGYN
With the oil type filters, you have to be very careful with ov3er oiling them or the oil gets all over the maf and can cause faulty readings.
There's also your install to consider. Check and double check the installation and all the hoses. Be sure they're not only in their proper places, but also that they're connected securely.
Those are really the two biggest things offhand. Time to start problem solving. Keep us updated.
Posted: Mon Oct 24, 2016 1:48 pm
by Fatpaul
Checked all the lines, looks like a hooked it up right.
Ran the codes and it is throwing the maf sensor now. Swapped my stock maf on the intake and seems like it fixed it but after driving for 30 or so minutes it threw another code. Check on it tomorrow.
Correction: it's aftermarket
Also I'm going to autozone to buy the maf cleaner spray and clean the filter in the morning
Re: Installed a K+N typhoon on 08 Vibe, throwing codes and not happy. HELP
Posted: Tue Oct 25, 2016 9:21 am
by circuitsmith
The base model and GT have different engines, so it sounds like a compatibility problem.
Posted: Tue Oct 25, 2016 9:52 am
by Fatpaul
This is the kit number for the part on the k+n website
Performance Intake Kit 69-8601TP
http://www.knfilters.com/mobile/mProduc ... =69-8601TP
Posted: Tue Oct 25, 2016 1:24 pm
by Fatpaul
It is for a gt only, guess I'm going to have to sell!
Posted: Tue Oct 25, 2016 3:10 pm
by Fatpaul
Posted: Thu Oct 27, 2016 10:29 am
by ImUrOBGYN
Good catch, circuitsmith. Sorry to hear about that, Fatpaul, but at least you know the issue, now.
