2003 vibe gt engine swap
Posted: Mon Sep 19, 2016 11:31 am
by sippy25
hello I am wondering can I install a 1.8 litre 1zz-fe into a vibe gt 2003 that had a 2zz-ge? will the 6 speed transmission hook up to it? thanks
Re: 2003 vibe gt engine swap
Posted: Mon Sep 19, 2016 1:00 pm
by runningslow
Yes, the 1ZZ will bolt to the 6spd. Many people have made the 6 spd swap into the base models.
I don't know the specifics, but the short answer to your question is yes, you can swap a 1ZZ in to a GT. You will need at least the engine and the ECU, after that, I'm clueless.
Posted: Wed Sep 21, 2016 4:16 pm
by sippy25
Thanks very muchly...any other suggestions are appreciated! Im going to give it a go. Is it a hard engine to pull?
Posted: Thu Sep 22, 2016 5:43 am
by runningslow
I've never done it personally, but I do not believe there's anything that would make it particularly difficult . There should be others around who have done it who would better suited to ask.
Posted: Thu Sep 22, 2016 6:34 pm
by trb
It is quite possible you would need a new wiring harness to match the engine since the two motors are different, but it might just mean re-pinning or moving wires around on the existing wiring harness. Not sure, but I would make sure what all you need to do before you start.
Good luck on it!
Posted: Wed Sep 28, 2016 9:00 am
by sippy25
thanks for the info watched a video on youtube pretty good. Yeah I probably need to use the other wiring harness with ecu is what I was thinking ill update as I find out.
