Ordered PBR Ground Wires...
Posted: Tue Aug 26, 2003 12:16 pm
by savedbyzero
Just ordered a set of ground wires from PoweredbyRice over at matrixowners.com Should be here within a week. I'll take some shots of install and post it, along with impressions and such. Can't be too bad for $50!
Re: Ordered PBR Ground Wires... (savedbyzero)
Posted: Wed Aug 27, 2003 12:38 am
by drunkenmaxx
what exactly do the ground wires do? what benefit do they bring? i got no clue
Re: Ordered PBR Ground Wires... (drunkenvibe)
Posted: Wed Aug 27, 2003 2:23 am
There's a long thread at http://www.matrixowners.com/ftopic5465.html Also some info on Lancer's DIY install at http://forums.genvibe.com/zerothread?id=5465Reportedly better performance due to better electrical ground connections throughout the engine compartment.
Re: Ordered PBR Ground Wires... (joatmon)
Posted: Wed Aug 27, 2003 3:08 am
by disneydj
Did this mod with the help of everyone. If you have an automatic it doesn't shift as hard... in fact it's barely noticable. I too wondered if it made a difference, and if it did why the manufacturer didn't do this... but hey wire is cheap... so I tried it out... good stuff! Also insulated the AC line at the same time... AC get's colder faster... a big help here in Orlando.
Posted: Wed Aug 27, 2003 3:49 am
by Lancer
Cool, get some good close up's of the wire and the connector's. I'd like to see how he put them together.
Posted: Wed Aug 27, 2003 11:28 pm
by QUIKAG
Not to say this isn't a good mod, but I would be careful. I learned the hard way that factory plugs and wires are pretty darn good. I put some aftermarket plugs and wires on a previous car and ended up having problems down the road. Good luck!
Re: Ordered PBR Ground Wires... (QUIKAG)
Posted: Wed Aug 27, 2003 11:44 pm
by NovaResource
QUIKAG, he means the hyper ground wires, not the spark plug wires.
Re: Ordered PBR Ground Wires... (NovaResource)
Posted: Thu Aug 28, 2003 12:09 am
by QUIKAG
quote:QUIKAG, he means the hyper ground wires, not the spark plug wires.My bad!
Posted: Thu Aug 28, 2003 12:21 am
by NovaResource
QUIKAG, what are your thoughts on these "extra" ground wires? I don't see how they really work but many claim they do produce small mounts of HP.
Posted: Thu Aug 28, 2003 1:54 am
by QUIKAG
quote:QUIKAG, what are your thoughts on these "extra" ground wires? I don't see how they really work but many claim they do produce small mounts of HP.I don't think it hurts anything, but I don't think it helps much either. Let's just say I won't be putting them on my car. Funny, how the guy on that matrixowner thread says he actually 'felt' a difference. If you can feel a supposed 3-5hp difference, then you should get a job at a car company testing development mules because your '(removed)' meter is pretty refined.
Posted: Thu Aug 28, 2003 5:45 am
by satur9
i got five different magazines here that tested the original hyperground wires on dynos they all showed some kind of inprovement from hp and tq to less electrical noise better stereo sound and crisper throttle response its so cheap you cant hurt but check them out. happies on newcelica.com sells them for forty i'll make my own for like 12 bucks.
Re: Ordered PBR Ground Wires... (satur9)
Posted: Thu Aug 28, 2003 9:21 am
by dmitri
whered u order them from....how do i contace pbr. thanks
Re: Ordered PBR Ground Wires... (dmitri)
Posted: Thu Aug 28, 2003 10:31 am
by savedbyzero
He's on newcelica.org and matrixowners.com...he goes by poweredbyrice(PBR). Look him up over there...
