Cooling fan surge
Posted: Tue Aug 30, 2016 11:28 am
by Vibrator03
Hey, other day used remote start. And as I walk up to car I notice the cooling fan surging. Not on off but spin and then spin faster. Happened for about 5 min...and went away. Later day same thing. Hasn't happened again (unless wife hasn't noticed and told me). It was NOT the idle speed fluctating. Tach remained at fast idle until it came down.
Thoughts? SUggestions? opinions?
thanks in advance
Re: Cooling fan surge
Posted: Thu Sep 01, 2016 10:24 am
by jolt
A fan relay going bad, or a fan going bad, or bad electrical connections in fan system? Air conditioning on and fan fast cycling to keep up with the heat?
Posted: Thu Sep 01, 2016 11:01 am
by MacGyver
Does this happen only when the vehicle has been started remotely?
I'd want to put a multimeter on the fan when this behaviour is observed and see what's what.
Posted: Thu Sep 01, 2016 6:17 pm
by Vibrator03
guessing its the motor, relay is just guessing.
however I appreciate the input.
Sorry I dont know how to use a multimeter, I pulled the relay today and fan came off but when I plugged back in it would click and thus fan would cycle on high and low speeds constant. I took video.
I went to crappy tire and priced a relay. $99.....frig that to guess.
The fan either works or it doesnt so I am not gonna condemn the fan....Ill try to get a relay from somewhere.
again, thanks for the advice.
Posted: Thu Sep 01, 2016 11:34 pm
by jolt
Posted: Fri Sep 02, 2016 4:38 am
by MacGyver
Vibrator03 wrote:I went to crappy tire and priced a relay. $99.....frig that to guess.
Stop shopping for car stuff at Canadian Tire and go to rockauto.com
Use the money you save to buy a multimeter and learn how to use it.
Posted: Wed Sep 07, 2016 4:30 am
by Vibrator03
I ordered one locally from a jobber here for $30. I was going to put it in but something else arose. My health is not well so I just took it to my mechanic and asked him to figure it out.
Thanks again for trying to help. Much appreciated.
Posted: Sun Sep 11, 2016 4:08 pm
by Vibrator03
Ok so I took it to my mechanic. Took him awhile to get it to duplicate issue but finally it did. The high pressure AC switch was causing the fan to on and off. Was low in freon as it was leaking from switch. The plug was green too. Goota find a plug at the wreckers, and had him order a new switch.
Just letting ya know.
again, thanks for your kindness
