Slow fuel fill
Posted: Sun Aug 21, 2016 10:50 am
by Yamahammer
I am having an issue where it takes forever to fill my car up with gas. I have to fill it at a trickle otherwise the pump clicks off. I have done some searching on Toyota cars with this issue, bt everything I see is for older cars that have a vent to the atmosphere. Has anyone had this issue, and what is the ticket to repair? Car runs fine and doesn't have a CEL or anything. Thanks
Re: Slow fuel fill
Posted: Sun Aug 21, 2016 11:11 am
by jayoldschool
Your car still has a vent tube, and it would be the most obvious cause for your symptoms. Plugged or kinked.
Re: Slow fuel fill
Posted: Sun Aug 21, 2016 11:46 am
by Yamahammer
Every hose I see plugs into something else. I see the big black box and the little one behind it. Neither of which vent to the atmosphere.
Re: Slow fuel fill
Posted: Sun Aug 21, 2016 2:33 pm
by jayoldschool
I guess I wasn't clear enough. Your car has a vent tube. It doesn't vent to the atmosphere. It is connected to a vapour recovery system. Start searching how to troubleshoot that.
Re: Slow fuel fill
Posted: Sun Aug 21, 2016 7:29 pm
by Derf
Were you able to inspect the entire fuel fill line. Behind the rear driver tire is a plastic panel that comes off allowing access to the fuel fill and vent/surge line. On mine, it was filling fine, but when I removed the panel their was a lot of debris wedged between the panel and line. Also something from the road could had hit the panel and bounced off and in the process dented the line.
Re: Slow fuel fill
Posted: Mon Sep 12, 2016 5:27 pm
by Yamahammer
I took the access panel off and everything is good. It looks like I need a special tool to take the vent lines apart. Does anyone know what tool that might be? Thanks
Re: Slow fuel fill
Posted: Wed Sep 28, 2016 1:01 pm
by lannvouivre
It shouldn't need a special tool besides flat blade screwdrivers. I was able to remove my EVAP canister with sockets, a ratchet, and flat blade screwdrivers. Just take your time and be careful. If you don't think you can get it off without damaging it, consider taking it to a mechanic. What you're looking to do is blow FROM the EVAP canister back into the fuel tank, so you'll have to figure out which one comes from the tank and which one goes to the engine.
