OEM style air filter vs oiled cotton filter
Posted: Fri Aug 05, 2016 8:22 pm
So, I have to eventually replace the air filter in my vibe. I have considered going with a Spectre ($25) or K&N ($50) or other oiled cotton type filter. This would be with the stock air setup, as CAIs are rather expensive. Eventually I may upgrade.
Here's the thing though. While I have heard that cotton does let in a little more air, I have heard it also lets in a little more dust as well, presumably due to larger pores on the surface. I have also read the Bob Is the Oil Guy reviews on filters:
http://www.bobistheoilguy.com/airfilter/airtest2.htm
http://www.bobistheoilguy.com/airfilter/airtest3.htm
So, the question I have, is it worth the additional $20-40 for a cotton filter that I believe the only benefit is you can reuse it, and possibly lets in more dirt? I am assuming that the reason you get more performance out of a K&N or Spectre cone filter is because it's attached to a CAI or other aftermarket intake, and the performance is not due to filter, but due to the shorter intake that doesn't snake through the car frame all over hell and back.
I'm sure this topic has been argued before, but I'd like to hear your guy's opinion on it.
