Good brand for rear brake cylinders?
Posted: Fri Jul 29, 2016 8:06 pm
by trevg
Hey all,
Yesterday I noticed a popping sound from the right rear while braking. Got the drum off today, turns out one of the cylinder pistons has a bad seal (see the pictures), so I'll need a replacement. I couldn't fine an OEM part number (can anyone help with that?) But here are some brands that make replacements:
  • Brakeware (at AutoZone)
    O'Riley's house brand
    Napa
    Altrom (also at Napa)
Anyway, does anyone have experience with any of these brands, or any recommendations?
Also, is it best to replace both rear cylinders at the same time? Haven't done this before so all tips are appreciated!
Thanks!
Re: Good brand for rear brake cylinders?
Posted: Sat Jul 30, 2016 12:32 am
by jolt
I have had good luck with NAPA. I found my local NAPA store is also cheaper on brake parts then my local Advanced Auto Store.
Posted: Sat Jul 30, 2016 12:10 pm
by Chiadog
2X Jolt! I like NAPA for parts that require accurate machining operations, close tolerances, etc.
Posted: Sat Jul 30, 2016 1:12 pm
by trevg
Thanks all! Wound up stopping at Napa, only 13 bucks, hopefully should last the next 160000 miles!
