Ticking noise from middle of dashboard
Posted: Fri May 27, 2016 8:14 am
by coppens1
Vibe User Group 270516 Ticking noise from middle of dashboard
Dear fellow vibe Owners, today when I started my 2005 vibe, I experienced a Ticking noise from middle of my dashboard. I turned the engine off and the key position to accessories, turned off the radio, fan, air conditioning, CD player, and the noise persisted. It stopped when I completely turned the key off.
Has any one else experienced this noise? what was the cause?
Re: Ticking noise from middle of dashboard
Posted: Fri May 27, 2016 10:14 am
by BustedVibe
Did it sound internal or external? How loud was it?
Could it be lifter tick? That's the only thing I could think of. Sometimes you can hear it even inside the car
Posted: Fri May 27, 2016 11:02 am
by kumquat
Probably not the lifters if the engine is off.
How quickly does it tick? Is it a regular rate and rhythm?
It's clearly something electrical. Do you have an aftermarket radio?
Posted: Fri May 27, 2016 1:22 pm
by BustedVibe
oops sorry I thought he said it only stopped when the engine was off not the key
Posted: Fri May 27, 2016 8:23 pm
by trb
Have you checked to make sure it is not the AC recirculate gear? The teeth on the gear break often and when that happens, the gear causes a clicking noise in the center of the dash. It often goes away if you press the recirc button.
viewtopic.php?f=17&t=3435&p=507341
Good luck with it
Posted: Sat May 28, 2016 1:48 am
by BustedVibe
This video might be relevant
https://www.youtube.com/watch?v=oUKgs6VIUY0
Posted: Sat May 28, 2016 12:00 pm
by jolt
I can't hear it from here ;) but I thing trb's reply has hit the nail on the head. The stripped plastic gear will make a sound like that as the teeth jump.
Posted: Fri Jun 24, 2016 11:52 am
by coppens1
You all have hit the nail on the head, and even provided a youtube film showing how to fix it. It is great being a member of this group! Thanks very much. JC
