VW wheels
Posted: Mon May 23, 2016 11:24 am
by xegwhts2uq
Please ...What VW 16" wheels fit a 2007 Vibe.....Thanks
Re: VW wheels
Posted: Mon May 23, 2016 3:24 pm
by jayoldschool
Any MK IV wheels. Beetle, Golf, Jetta, etc. Not Passat (bigger bolt pattern). 15s, 16s, 17s, 18s.
Re: VW wheels
Posted: Tue May 24, 2016 5:24 am
by vibrologist
......but watch for the offset.
Re: VW wheels
Posted: Tue May 24, 2016 8:46 am
by xegwhts2uq
The add says off set 42,will that work? What about lug nuts?......Thanks
Re: VW wheels
Posted: Tue May 24, 2016 10:26 am
by vibrologist
Offset or back space determines the track width. our Vibes have regular offset, many VW have high offset. If you happen to get high offset wheels and put them on your Vibe the track will be narrower. you can get spacers to make up for it, but they are an added cost, and principally, I don't like the idea.
I am not sure what our offset is.
This website is helpful. It has a video on how to measure backspacing: http://www.roadkillcustoms.com/hot-rods ... z49b8lEmFi
If you search around you will find similar reference charts. This one i.e.: http://www.wheel-size.com/
Re: VW wheels
Posted: Tue May 24, 2016 11:02 am
by jayoldschool
Just check the offset and compare with the stock Vibe specs.
For lugs, you need conical seat lug nuts. Don't use the ones that come on Vibe alloys.
Here's a comparison:
