Replacing Valve Cover gasket..cure time?
Posted: Thu May 19, 2016 6:11 pm
by Lambo50
I plan on replacing my valve cover gasket tomorrow after I get off work early. I already have the gasket an such but curious how long should I wait before driving due to the Super Black gasket sealer? I know I will only be using the sealer in two small spots so does it really take 24hrs before I can drive again?
Re: Replacing Valve Cover gasket..cure time?
Posted: Fri May 20, 2016 5:33 am
by lannvouivre
You need to leave it alone the full recommended time or you might wash the silicone gasket off with oil splash and have it relocate into a critical area and plug an oil gallery. It probably doesn't take that long, but they give you that long period so you will not have problems, or worse, a catastrophic error like what I described.
Posted: Fri May 20, 2016 4:09 pm
by Lambo50
lannvouivre wrote:You need to leave it alone the full recommended time or you might wash the silicone gasket off with oil splash and have it relocate into a critical area and plug an oil gallery. It probably doesn't take that long, but they give you that long period so you will not have problems, or worse, a catastrophic error like what I described.
Yeah the Ultra Black sealant states allow 24hrs for cure time. Just seemed a bit much. Plus with my busy schedule its hard to not have to go anywhere within 24hrs. I guess I will have to wait until I have some consecutive days off.
Posted: Sat May 21, 2016 7:33 pm
by cptnsolo77
Have you tried tightening down on the valve cover bolts ? I had a leak and re-touqueing the bolts stopped the leak. I have no new oil stains in my driverway for over a week
