backup camera install on 2009 vibe base
Posted: Wed May 18, 2016 6:30 am
Hi all,
I have a license plate camera and a rear view mirror display (mostly) installed on my 2009 base-- everything except for the actual wire cutting/soldering. My thought is to make the wiring as simple as possible: have the display and camera powered by the reverse lamp. I am fine with it only coming on when I am in reverse, and it was easy routing the wires through the headliner-- avoiding the dash entirely.
I already have an RCA cable and +12V power wire routed from the tail light area to the mirror-- and my idea is to just ground the mirror to the existing onstar ground wire that is already up there (although I have to figure out which one it is). Then at the tail light, I connect the reverse lamp cable to: the camera. mirror 12v, and reverse trigger wire for the mirror--and ground the camera somewhere near the tail light as well..
My question is: is there any risk in powering the mirror and camera from the tail light lamp wire-- will it blow anything up or not provide enough current? The mirror says that it uses 4W... I am going to get a multimeter to test everything before I make the connections. I guess if it does not work, then hopefully there is an ACC wire near the tail light to try the other way.
Basically I am just looking for a sanity check before I attempt this. I've soldering before, but have not messed around with my car other than replacing the tail lamp assembly, and the infamous volume knob replacement.
Thanks!
Thanks!
