Hey all
I have a 2003 Vibe GT, pushing 200,000 miles and it's started to have some issues. We first noticed that between 20-50 mph or so there is a pretty load noise coming from front of the car, not particularly to either side. The best way I can describe it is like really loud road noise -- just a loud, indistinct whir or slight rumble. Above 50 or so mph, it becomes less noticeable, though it may just be that the engine and actual road noise are overtaking it. The first thought was a wheel bearing, but it's definitely not to one side or the other, and the right front wheel was rebuilt with a new bearing a year or two ago, so it would be odd for both sides to fail at once. We put it up on jack stands and started playing with it this afternoon. There are a number of noises coming from the front, and it seems like the main rumbling noise is present at all speeds, it just wasn't noticeable when actually driving. The oddest thing that we noticed is that when you let it idle in first gear, the front right wheel spins at idle speed like you expect, but the front left starts spinning at first and then just stops on its own, you can even stop it with your hand. In neutral you can spin it with your hand, so it doesn't feel like the brakes are activating, but when you go from idling in first to neutral it quickly slows down, as if there is something in the transaxle that it slowing it. Any thoughts? I really only need this car to last a couple of months more, so I am really hoping it doesn't turn into a new transmission or something. I don't even think the car is worth the cost of the replacement.
