low/rough idle
Posted: Fri May 13, 2016 9:47 am
by Jschaf024
cleaned both battery terminals today as they were corroded. took negative off first, hooked up last. started car and is now idling very low and somewhat rough, if i let it sit it will stall after a minute or so. is there something i'm missing here? some electrical reset?
Re: low/rough idle
Posted: Fri May 13, 2016 11:55 am
by ImUrOBGYN
As long as you know you didn't short something out while removing/installing, there generally isn't an issue like you mentioned. Some cars after being disconnected for awhile will take a bit to remap, etc. but I've never heard of an issue that major.
Best I can say for now is to go back out and really recheck those cables and their connections; making absolutely sure everything is in good contact. Then check the area you were working around for anything you may've knocked a bit loose. Sometimes, things are 'on the verge' and all it takes is a little movement or bump.
Re: low/rough idle
Posted: Fri May 13, 2016 1:27 pm
by SeattleJeremy
The ECU needs to go through the relearn process. This is normal after disconnecting the power to the car. Let it idle for a few min, it may stumble, but it's not likely to stall.
Re: low/rough idle
Posted: Fri May 13, 2016 1:58 pm
by vibrologist
Please provide year and mileage of the car. What else has been done recently or has been missed?
It has to go through a relearn process but if it is stalling there is something else afoot.
how old are the spark plugs,
is the MAF sensor dirty,
vacuum leak somewhere?
Re: low/rough idle
Posted: Sun May 15, 2016 8:12 am
by Jschaf024
Hi, it worked itself out after driving around for awhile. Sorry for the ignorance about this, and I see another post about this very same problem now. So thanks for the responses.
I replaced the spark plugs with ngk iridiums. It's an 05' base with 112,000 bought used with no service records. So I am assuming nothing has been done. My list of maintenance includes
ATF change,
coolant flush and change,
clean MAF,
throttle body,
and I saw something on here called IVAC to clean as well.
I'm driving cross country in July and want her in top shape beforehand so I'll be resourcing from here quite a bit. Thanks for the input
Re: low/rough idle
Posted: Sun May 15, 2016 11:32 am
by Caretaker
I get the low idle rumble when coming to hard stops. I think it is a carbon thing. I have all the components cleaned of carbon but I still get an occasional rumble. I have not replaced my OEM ignition coils, even though my plugs are new iridium. Good luck with your cross country drive. I just did that last year and my Vibe did wonderfully. 105,000 miles on the odometer now and the car is really enjoying the "always warm" climate. No more snow and cold for my baby.
Re: low/rough idle
Posted: Sun May 15, 2016 2:09 pm
by Jschaf024
thanks,
im moving from michigan to southern california. hoping to get all this maintenance done myself before i go, but the weather has been crap. It snowed today..its may 15...ridiculous.
cheers
Re: low/rough idle
Posted: Sun May 15, 2016 2:52 pm
by Caretaker
...he,he....bring some extra money with you for car insurance. It is a rip off here.
Re: low/rough idle
Posted: Mon May 16, 2016 6:28 am
by ehoff121
Jschaf024 wrote:and I saw something on here called IVAC to clean as well.
You mean the IACV, a.k.a. Idle Air Control Valve, attached to the throttle body. :D
Here's a great thread on this: viewtopic.php?f=17&t=36489
Re: low/rough idle
Posted: Mon May 16, 2016 7:27 am
by vibrologist
Jschaf: Go to a trusty GM dealer and let them check if all the recalls have been done, especially the recall on the PCM.
