2003 vibe gt driver door stock locked
Posted: Wed May 04, 2016 5:09 pm
by isaum
My 2003 vibe gt driver door is closed and locked and stuck locked... The actuator makes no noise nor can I unlock manually.. Any ideas I'm getting tired of climbing over my passenger seat to get in daily
Re: 2003 vibe gt driver door stock locked
Posted: Wed May 04, 2016 9:11 pm
by jolt
Check out this thread:
viewtopic.php?f=17&t=44212&p=503924&hil ... ck#p503924
This has already been talked about.
Posted: Thu May 05, 2016 2:48 am
by isaum
How do you get the actuator to let loose after the door panel is off I need it to let free so I can open the door and I can unbolt it from the door don't I?
Posted: Thu May 05, 2016 9:16 pm
by jolt
After doing a search for you, here is a link to a YouTube video that shows you how to replace the door handle. In the video you will see how to get the inner panel apart. You will also see the linkage from the door handle to the latch and the cable running to the inside door handle in that video which will give you idea of what you should be looking for as the two door handles work the door latch. These are the parts that you need to move, push, or pull to trip the door latch open. Look inside at the door latch and try pulling or pushing on the linkage to trip the latch open. Good luck>
https://www.youtube.com/watch?v=79PUk7zEL44
