Is the OEM alloy wheel for Vibe 2010 2.4L hub centric?
Posted: Fri Apr 29, 2016 5:25 pm
I need to get the size of the wheel hub centre bore.
It's not 54.1mm as I found online, because my 54.1mm inner diameter hub centric rings did not fit.
But now I had the second (non-OEM) set of wheels installed on car and no tool to remove them, I can't make a measurement on the wheel hub directly.
If the OEM wheels are hub centric, can I measure the centre bore inside the removed OEM wheels and assume the centre bore size of the wheel hub is the same?
Thanks.
Thanks.
