Loose Door Handle Trim
Posted: Sat Apr 02, 2016 3:35 pm
by tzuleger
Hey everyone :)
Hopefully somebody can point me in the right direction with this. Just picked up this Vibe a week or two ago and noticed that the trim around the lock on the passenger side door is coming loose. I thought about using an adhesive as a temporary fix but I'm worried that might get inside the lock and cause some issues. Has anyone had this problem before? Either way, I could use some suggestions as I am not sure how to go about this.
Thanks!
Re: Loose Door Handle Trim
Posted: Sat Apr 02, 2016 5:14 pm
by Derf
It appears the lock cylinder is sliding out of position. Once the door is open at the same level as the door handle should be a plastic cap on the side normally facing the door latch. Remove the plastic cap inside is a torx screw that holds the lock cylinder and door handle in place, check to see if the screw or mounting hardware is loose.
