Bought 2004 w/ bad 5 speed tranny (did not know)
Posted: Thu Mar 31, 2016 10:52 am
by c3VIBE
I bought a 2004 5 speed built for Canada with Kph instead of Mph on outer dial. Anyway, could not test drive above 3rd due to no plates. Got plates drove it, 3rd, 4th & 5th all had a whine to them. From what I read it was bearings and others had problems with this trans. $3200 to have a reman installed. Thanks to Genvibe I just tackled and finished dropping the trans, installing new clutch & throwout, turned flywheel and having the transmission rebuilt. Also did new struts, links, rotors, pads, clutch slave cylinder, intake manifold gasket, plugs, thermostat & rad. fluid. Also, this is crazy, it has a block heater?! :shock:
Re: Bought 2004 w/ bad 5 speed tranny (did not know)
Posted: Thu Mar 31, 2016 1:30 pm
by jayoldschool
Don't have that trans rebuilt. Swap it for a 6 speed!!!
Posted: Fri Apr 01, 2016 7:04 pm
Welcome to GenVibe. With all that work done to it how much did it set you back $$$ ? Did you pretty much get the car for free seeing how it needed so much work done to it? Great to see you save it from salvage :D
Posted: Sat Apr 02, 2016 12:38 pm
by vibenvy
Welcome to GenVibe! You should start a thread in the Garage Forum to document all the work you've done and do in the future to your "new" Vibe. Be sure and post some pictures too ;)!
