Shift kit for automatics? Or way to firm up shifts?
Posted: Wed Mar 30, 2016 5:48 am
by samsonite
Curious if there is a method for quickening and/or firming up shifts? I might be doing some towing with my Vibe in a few months when I move. I have a 1.8l fwd '04
Re: Shift kit for automatics? Or way to firm up shifts?
Posted: Fri Apr 01, 2016 1:16 am
by lannvouivre
http://www.monkeywrenchracing.com/produ ... ts_id=1983 valve body
http://www.monkeywrenchracing.com/produ ... ts_id=1036 torque converter
Those are your only options besides swapping to manual, and they cost almost as much as a 6-speed manual anyway.
Posted: Thu Apr 14, 2016 9:08 am
by Kazu03gt
Or you can look into removing 1,2 and 3,4 accumulator springs for a cheaper solution. It will engage into gear a little faster and stiffer. But i would personally buy the valve body for long lasting results.
Posted: Thu Apr 14, 2016 11:58 am
by Chiadog
Cheapest possible fix is to switch to a compatible synthetic tranny fluid, if you haven't done that yet.
