Car vibrates at highway speed
Posted: Wed Mar 23, 2016 9:06 am
by viber15
Just recently my car started to vibrate at about 60 mph. It sounds and feels like a rear tire issue, but when I take a look at them, the tires are not abnormal in any way. They are not flat, there are not any visible issues. The vibration is rhythmic and definitely gets stronger/faster the quicker I go, and weaker/slower the slower I go. Any ideas?
Re: Car vibrates at highway speed
Posted: Wed Mar 23, 2016 12:43 pm
by ehoff121
Some causes of wheel vibration are not visible.
First, do you have access to a torque wrench? The lug nuts should be at 76 ft. lbs. -- any higher and it may cause problems. It costs nothing to check them (unless you need to buy a torque wrench, which is good to have anyway
Next, when were the tires balanced last? If more than 5,000 miles, it could be contributing.
Have you rotated the tires? If not, you could try swapping the fronts to the back and see if the vibration moves with it.
Also possible that the wheel bearings are bad.
