Performance headers?
Posted: Sat Feb 27, 2016 5:36 pm
by TraumaForYou
:D where can I get a good performance header online? Looking for an upgrade but don't of any good brands.
Re: Performance headers?
Posted: Sun Feb 28, 2016 8:01 am
by TraumaForYou
Found the number for the one from the performance thread. http://www.amazon.com/DC-Sports-THC4405 ... er+THC4405 can anyone verify if this will work on my 06 base?
Posted: Sun Feb 28, 2016 9:34 pm
by B14CK_H4WK
PPE makes a good set
http://ppeengineering-onlinestore.com/C ... FE_c15.htm
here a photo of the end of mine on my car
Posted: Mon Feb 29, 2016 9:24 am
by lannvouivre
TraumaForYou wrote:Found the number for the one from the performance thread. http://www.amazon.com/DC-Sports-THC4405 ... er+THC4405 can anyone verify if this will work on my 06 base?
Posted: Mon Feb 29, 2016 1:18 pm
by TraumaForYou
Very nice! Thank you!
Posted: Tue Mar 01, 2016 2:37 pm
by TraumaForYou
How did the install go on that when you got it?
Posted: Tue Mar 01, 2016 10:57 pm
by lannvouivre
It was easy. The O2 sensor hates being removed, so use some O2-safe antiseize on the threads when you install. The spring bolts can be overtightened; you want to get them snug enough to make a seal, but still able to flex because that's what these cars use instead of the flex-pipe.
You can install the header from the top, but I'm not sure the old one can come out the top or not. Just maneuver it over the transmission. The 2ZZ is a different story, so be relieved you don't need to do that (those manifolds are actually headers and only need to be port-matched anyway).
Posted: Tue Mar 08, 2016 5:56 pm
by viber415
Does the DC header bolt right on to the midpipe or is modification required?
Posted: Thu Mar 10, 2016 11:30 am
by lannvouivre
Should bolt up. These cars don't usually have much difference between the individual cars.
Posted: Sun Feb 26, 2017 1:28 pm
by TraumaForYou
Well, ive been spraying all the header bolts with AC delco rust penetrator daily to make it easier when loosening the bolts. I have the header and i just got the heat shield off the old one which was not that easy. Should I look into replacing all of the bolts in the assembly or should i be ok sticking with the factory bolts?
Posted: Wed Apr 26, 2017 1:16 pm
by BassetVIBEs1984
if the bolts dont strip or jam the threads up when you pull them out you should be ok to re-use them.
