Radiator Fan noise
Posted: Fri Feb 05, 2016 4:30 am
My 2006 Vibe is making a lot of noise that seems to be coming from the rad fan. Has anyone had issues with this before?
Thx
Thx
https://forums.genvibe.com/phpBB3/
Spray with some ATF (automatic trans fluid) and let it sit on them for a day or two without running the car. It works better than actual penetrating oils (and don't even bring up WD-40 because that stuff is meant to repel water and is terrible at everything else). ATF is highly flammable, so I wouldn't recommend getting it hot on a fan motor.GDV wrote:The fan blades seem to have quite a bit lateral movement. The screws for the motor are very corroded, might have to replace the whole assembly?
