steering wheel shaking
Posted: Sun Jan 24, 2016 6:29 pm
Hi -
Got four new tires 1 year ago. Also replaced front brakes (pads & rotors) the same month. No issues.
A few days ago, I checked the tire pressure & put air in all four tires. I did not use the vehicle for 2 days due to a blizzard. When I took the vehicle out after the storm, the steering wheel was shaking at higher speeds (about 50/55mph & above). Checked all four tires; pressure was good & tires seem to be wearing evenly. CV boots all look fine. Struts do not seem to be leaking oil.
Based on research, it looks like the first thing to check is to ensure that the tires are balanced. I was concerned, because the vehicle was driving fine Thursday & by Sunday (3 days later) the steering wheel was shaking quite a bit at higher speeds. I also thought that it is possible that a wheel weight (or loose wheel weight) was knocked off while clearing snow from the vehicle after the storm & now a tire is not balanced.
Wanted to post to see if anyone had any other suggestions. Any help is definitely appreciated! Thanks.
