Where is the VSS located?
Posted: Mon Jan 18, 2016 7:19 am
Hi guys, new here.
I'm having a lot of trouble trying to find the vehicle speed sensor on my 06 vibe. I haven't had use of my Speedo since I had my clutch serviced about a month ago and I'm pretty sure they forgot to reconnect it as it worked before I had my clutch replaced. I've searched all over Google and can't come up with anything concrete. Or any diagrams showing where it is located.
most explanations I've found say its to the right and down from the bell housing of the transmission if your standing at the drivers side fender. However the only thing I can see connected is the reverse light switch.
If someone could post a picture or a better explanation of where it is on the transmission, I'd greatly appreciate it. Mine is a 5 speed without ABS. Thanks!
