Water leaking from driver side headliner
Posted: Sun Jan 17, 2016 12:40 pm
by coppens1
Dear Vibe Users, I recently purchased a 2005 Vibe, and we had a lot of rain recently. I notice water leaking from the joint where the headliner meets the plastic covering the roof column. It is dripping on my thigh when I drive. I checked for a blocked drain, but there none by the driver door. Has anyone else had this problem?
I noticed someone else had a leaks problem, too, ("Water leaks on the driver's side") but he is getting water on the front and rear floormats.
Re: Water leaking from driver side headliner
Posted: Sun Jan 17, 2016 3:26 pm
by vibrologist
You did not say if you have a moon roof. If you do the drains may be blocked. They are running towards the rear of the car. If you take the interior side panels out in the trunk area you can see them. I would try blowing compressed air through them. I don't know if there are any towards the front.
If you don't have a moon roof there may be a problem with the seal of the windshield.
Posted: Mon Jan 18, 2016 12:43 pm
by mktrat
Could also simply be a poorly adjusted moonroof overflowing the drains (assuming one is present!)
That's how mine was for a long time. Took forever to figure it out. (I didn't know about genVibe at the time)
Posted: Mon Feb 01, 2016 12:23 pm
by coppens1
Sorry, I forgot to mention there is no moon roof. The leak is just inside, maybe coming from the black rubber grommit by the rails on the roof.
Posted: Tue Feb 23, 2016 1:26 pm
by coppens1
Now it is leaking from both sides!
Posted: Wed Feb 24, 2016 12:15 pm
by lannvouivre
The grommets can be pried off gently no problem. Look under the fronts of them and see if you can spot anything.
Posted: Thu Feb 25, 2016 10:56 am
by coppens1
Dear lannvouivre, thanks for replying. Do you think it can be fixed by prying the two grommets (both sides) off and using silicon caulk? JC
Posted: Fri Feb 26, 2016 11:50 am
by jolt
Has the windshield been replaced? It may be leaking from the top of the windshield if the windshield was not installed properly.
Silicon caulk will work if the surfaces are clean and rust free. You may want to pull some of the interior trim to verify where the water is coming in at, and after fixing the problem, to verify that it is not leaking any more. Down the road, you may run into some electrical problems as the water that has leaked into the car will corrode electrical connections. It all depends on how much water came in and were it ran. If it is dripping from up above, chances are more water is also running off to the side behind the headliner.
Posted: Wed Apr 20, 2016 8:42 am
by coppens1
Dear Jolt, I think you hit the nail on the head when you asked about windshield replacement.
What is amazing is that there is no water till you move the car after a rain. When you move forward, you get a flood.
My analysis is that the hollow windshield posts fill with water and overflow when you move the car.
I have tried caulking the front part of the channels that run from the luggage rack forward to the windshield, to no avail.
I took the car to an auto leak specialist this morn, and he looked it over, noticed the windshield is an aftermarket glass, and told me the leak is from an improperly installed windshield. He said the windshield has to be removed and reinstalled, and if it breaks, I have to pay for a new windshield, too.
I am going to try caulking the long joint between the top of the windshield and the roof, all the way across the roof, around 4 feet. What do you think?
Posted: Fri May 27, 2016 7:44 am
by coppens1
Vibe User Group 270516 Water leaking from headliner at joints with front roof pillars
Dear Vibe Owners, I have read of several other owners also having difficulty with Water leaking from headliner at the joints with front roof pillars.
In my case, I finally went to an auto repair shop that specializes in fixing leaks. After a few seconds the expert there informed me that my windshield had been replaced and improperly installed. He quoted $200 for taking the windshield out and installing it again. He also said that frequently when taking the windshield out, it would be damaged, and have to be replaced, quoting $350.
I bought silicon caulk and filled the 1/4" gap between the top of the windshield and the roofline. I have had no leaks for the past month.
Posted: Wed Jul 07, 2021 8:07 am
by coppens1
Vibe Owners 070721 Passenger Headliner Leak
Dear Vibe Owners, I still have a Headliner Leak, but on the passenger side of my 05 Vibe, from the joint where the headliner meets the plastic covering the roof column..
The problem was previously diagnosed as a leaking windshield. I was going to have my windshield replaced, but Safelight won't replace it because of some corrosion at the top of the windshield. I bought Fix Tape Rubberized Waterproof Tape, for Boat Repair (Clear, 4 inches x 5 feet), and put it all the way across the top of the windshield. The leak continued.
It appears the leak is from the luggage rack, and seems to be coming from the driver side luggage rack. When I covered the passenger side luggage rack and tested it in the rain, the leak persisted. So it has to be coming from the driver side luggage rack.
Has anyone else had the lead problem? How did you fix it?
Posted: Wed Jul 07, 2021 8:20 am
by coppens1
Dear lannvouivre, here is your post of 2016: "The grommets can be pried off gently no problem. Look under the fronts of them and see if you can spot anything."
I need further instruction as to how to pry the grommets off. Can you send me a photo? Jim Coppens
Posted: Wed Jul 07, 2021 8:21 am
by coppens1
Posted: Thu Oct 27, 2022 8:37 am
by coppens1
Shame on you, ihjwernml579, for wasting our time. Your post had nothing to do with the topic, and appears to be advertising. JC
Posted: Sun Oct 30, 2022 7:53 am
coppens1 wrote: ↑Wed Jul 07, 2021 8:07 am Vibe Owners 070721 Passenger Headliner Leak
Has anyone else had the leak problem? YES .... ME :cry:
My 2004 Vibe GT just started having this problem about 3 months ago. I'm definitely convinced that it is due to the windshield frame corrosion being totally gone, and allowing water to enter the pass side headliner. The pictures pretty much tell the story. My solution will to be have the windshield removed , repair any/all rust & repaint, then reinstall windshield. Ill post pics & progress when I get started. Probably in a month or so but not too much longer than that.
Posted: Mon Oct 31, 2022 7:51 am
by coppens1
Mine is leaking from the Passenger side headliner. I tried all kinds of things, including caulking and tape over the windshield top, then discovered :
1. Does not leak while driving car.
2. While parked, If you use a small 5' x 7' tarp that covers the windshield back about half way, you get no leaks. The tarp is held down by the windshield wipers and 8 small magnets. It only takes about 2 minutes to put the tarp on the windshield.
I can take a photo if anyone is interested. JC
Posted: Mon Oct 31, 2022 7:29 pm
coppens1 wrote: ↑Mon Oct 31, 2022 7:51 am
YES. I'd be curious if you have rust along the top of the glass similar to what I have. That is clearly where my leak is originating from.
Posted: Tue Nov 01, 2022 11:55 am
by coppens1
I will take some photos of the rust, and of the tarp that solved the problem.
In my case it is not leaking from the upper windshield. I put clear Gorilla tape there, all the way across the top of the windshield. It didn't stop the leak! I can''t really figure out where the leak is. I just have a solution. Jim
Posted: Wed Nov 02, 2022 9:15 am
by coppens1
tpollauf 021122 Photos of windshield top, and tarp
Dear tpollauf, here are Photos of windshield top, and tarp. Since the Gorilla Tape didn't work, I removed it. I still have a lot of clean up to do from that. But at least the tarp stopped the leaking. Jim
SDC14031Vibe w Tarp.JPG (331.01 KiB) Viewed 79017 times
SDC14036Vibe w Tarp.JPG (332.69 KiB) Viewed 79017 times
SDC14035Vibe w Tarp.JPG (335.73 KiB) Viewed 79017 times
SDC14034Vibe w Tarp.JPG (333.06 KiB) Viewed 79017 times
SDC14033Vibe w Tarp.JPG (330.51 KiB) Viewed 79017 times
Posted: Fri Nov 11, 2022 1:33 pm
Wow ... you went to extremes BUT at least you temporarily controlled the leaking! Mine is getting worse by the week. Today, we got the remnants of that Hurricane along the lakeshores of Lake Erie and it rained all day. The Vibe's interior got even wetter since the last rain. Passenger seat is totally soaked & the headliner is getting worse. I'm going to have to do something sooner than later. Was hoping to put this off till December. Not sure now :?
Posted: Sat Nov 12, 2022 6:13 am
by coppens1
The tarp is not the ideal solution, but it works and is inexpensive. I put the tarp on when there is rain forecast, and I can't park the car in my carport. I have not had the leak in a year because of the tarp.
Before I discovered the tarp solution, I tried everything, but was unable to pinpoint the leak. So the tarp was the simplest solution for me.
Let me know what happens with your leak, and if you discover the exact source. Jim
Re: Water leaking from driver side headliner tpollauf
Posted: Mon Nov 28, 2022 8:14 am
by coppens1
Vibe Forum 271122 Leaking from passenger side headliner.
Dear tpollauf, since we are both having exactly the same problem with the leak, and it is a complicated problem, I think we should talk by phone to go over all the details of our leaks and the solutions.
But I don't want to give you my phone number in a public forum. I can give you my email address, or have you go to a website where I have a secure registry, and you can register there so we can establish communication that way. Let me know. Thanks, JC
Posted: Mon Nov 28, 2022 8:27 am
Sure. Email me at tpollauf@hotmail.com I'm not worried about privacy and am not on a witness protection plan either :lol: We'll go back & forth that way BUT will still upload progress to the GenVibe site so others can benefit from this.
My theory on this topic is that the robotics which painted our vehicles somehow did NOT apply enough primer, color, clearcoat on the passenger area where this rust has eaten away the metal and allowing rain to pass through.
I'm waiting for a space down at my shop, which I share with a couple retired brothers, where I'll then park the Vibe for a week or so. We have a friend who does automotive glass for a living and he'll stop by to remove the windshield. While out, I'll perform the body work. Once completed we'll have our friend reinstall the windshield. It's looking like it's going to de mid-December for me.
Posted: Tue Nov 29, 2022 9:44 am
by coppens1
Dear tpollauf, I sent you an email. Let's talk. If this leak is widespread, we may have a manufacturing defect. JC
Posted: Sat Dec 03, 2022 11:58 am
Most of my early cars had perforating rust, sometimes more bondo than metal, and there were a lot of rusted out cars on the roads. Don't know if it was a change in winter road treatments, better steel, something else, but where I am it is now rare to see a rusty car. Hurts to see the bubbling rust on a Vibe. Unfortunately, Vibes came with a 6 year warranty on rust through corrosion, and being out of production for over a decade it would be pretty tough to get GM to do anything about it now.
Posted: Sat Dec 03, 2022 12:44 pm
by coppens1
My Vibe is in Florida! It is leaking in the same places, i.e. left and/or right side headliners as the other contributors. I took the car to a couple of body shops, and they told me the problem was because of an improperly installed replacement windshield. But I haven't heard this from other contributors. To stop my leak, I tried caulking everywhere I could think of. No effect, still leaks.
When I tried putting a small tarp on the car when parked (as shown in the photos I posted here) covering the windshield and half the roof, the leaking stopped.
Strangely enough, when you drive the car reasonably fast in a rainstorm, it doesn't leak! JC
Posted: Mon Dec 19, 2022 8:45 am
by mktrat
Make sure you check the roof rack attachment points. Mine was leaking around the front driver side location.
Also, a bead of caulk around the windshield molding has seemed to help immensely.
"when you drive the car reasonably fast in a rainstorm, it doesn't leak!"
It needs to soak to leak for me too. Sitting parked outside during a rainstorm will do it every time.
Posted: Wed Dec 21, 2022 10:26 am
by coppens1
Caulking the roof rack attachment points didn't help in my case. Also a bead of caulk around the windshield molding did not help.
The only thing that helped is the tarp over the windshield, and over the front half of the roof rack.
It'a a strange leak! JC
Posted: Thu Dec 22, 2022 10:44 am
by mktrat
I also ran a beam from the roof rack attachment to the windshield. I kinda started caulking any and all seams and junctions.
Posted: Thu Dec 22, 2022 10:53 am
by coppens1
Dear mktrat, I am not sure what you mean by "I also ran a beam from the roof rack attachment to the windshield." JC
Posted: Thu Dec 22, 2022 12:26 pm
coppens1 wrote: ↑Thu Dec 22, 2022 10:53 am Dear mktrat, I am not sure what you mean by "I also ran a beam from the roof rack attachment to the windshield." JC
Look like a typo to me. I'm sure he meant to say "ran a bead of silicone/sealant from the roof rack to windshield". Looks like I'm still a few weeks out before I get started on my leak. I will likely pull it into the "unheated" portion of the shop and at least get started. Headliner and all trim pieces will come out first. Once totally removed I may take it outside and "simulate rain" so I'll definitely be able to see where it's leaking. Have to watch the weather though .... it's winter up here now and don't want it to freeze anywhere.
Posted: Fri Dec 23, 2022 10:29 am
by coppens1
thanks for your input.
I have a call to you, on my list of things to do. Maybe tomorrow.
Have a Blessed Holiday. Jim
Posted: Fri Dec 23, 2022 3:35 pm
by tmc
I've had this issue of and on with my vibe for a couple years - at first just sealing the spot where the roof rack channels meet the windshield seemed to help but it always came back. I now think it's a broader windshield seal and rust issue (mine was replaced a while back), made worse by the fact that those roof channels dump all the water right down the side edges of the windshield.
I just caulked all the way around the top and sides of the windshield seal (prying the rubber seal away from the metal as I went to get it in there). So far it seems mostly fixed!
Posted: Wed Jul 05, 2023 8:20 pm
coppens1 wrote: ↑Sat Dec 03, 2022 12:44 pm I took the car to a couple of body shops, and they told me the problem was because of an improperly installed replacement windshield. But I haven't heard this from other contributors.
Today, I FINALLY had room in the shop AND our buddy/friend, who does windshields for a living, CONFIRMED that my 2004 Vibe windshield was NOT OEM and that it was improperly replaced by "who knows" and due to the improper installation, caused it to rust out and thus eventually leak. Very thin bead of caulk/sealant on top of a likely scratched/scraped exposed metal lip, from them scraping the original windshield out, is what happened. With the bead being very thin, it barely gripped the glass in some areas AND did not allow room for "flexing" with the car. When attempting to cut out the old bead, he noticed some areas where it was damn near glass on metal, which made it almost impossible for him to get his cutting tools in there to safely remove it. Unfortunately he "cracked the windshield in the process of removing it. He said this was one of the more difficult windshields that he removed in his 25+ years of working in the glass industry.
Pics of todays progress below ..................................
My Vibe's resting place for the next few weeks. Inside the paint booth.
That's some nasty rust under there :o
Looks even worse when up close :cry:
Windshield removal GONE wrong !!!
Luckily, it did NOT rust through all the way .... yet anyways! The rust started out at the base or "under" the sealant and then spread upward until it became visible just past the seal. I just quickly scraped & burred the rust away to see wow bad it was. Will likely sandblast some of this too, to where I get solid metal exposed.
Our Vibe's headliner, acts like a channel/gutter and the water collected in it and ran either left or right (depending on the incline and where the leak was located from) and collected onto the A-pillar. The back side of the headliner is water repellant thus it doesn't show any signs of leakage until it spills over at the drive or pass pillars.
More progress coming in the next few weeks ...................................
Posted: Thu Jul 06, 2023 10:33 am
by coppens1
Dear Tim, nice photos. I am still using the tarp, as shown in the photos, but mostly parking the Vibe in the Carport, while both my Lexus' (98 and 01) are out in the rain. It's a shame that such a well engineered vehicle should have this problem. I haven't heard if the twin, the Toyota Matrix, has the problem. Jim
Posted: Thu Jul 27, 2023 9:30 am
by Crowquill
The 03 Matrix seems to be susceptible. I found this thread after getting dribbled on from the driver side A-pillar after a heavy rainstorm. Mine also has a replacement windshield. I've yet to check for rust or pull the headliner to see if I can tell where it was coming from. I've only had it happen twice and that was after a very heavy rain.
I recently pulled off the passenger-side skirt after discovering a good deal of rust underneath. Wouldn't have know about that except that I could see it from under the car. Wouldn't surprise me if I've got some rust going at the windshield.
Posted: Thu Jul 27, 2023 12:21 pm
by coppens1
I wish you luck. I tried everything I could think of, except a $2000 repair, to stop the leak.
I finally found that putting a cheap green 6' x 9' tarp over the windshield and half the roof, with magnets, stopped the leak when the car is parked.
Strangely, it doesn't leak when you are driving the car. See my photos a few messages above. Let's talk when you can figure out how to give me your phone number without telling the world. JC
Posted: Fri Sep 08, 2023 8:42 pm
OK ... so it's been two months now and moving extremely slow :o The Vibe should be painted next week, then the new windsheld installed. This rare Orange metallic paint is the MOST expensive of all the colors! :evil: Just over $100 for a pint ... OUCH! Anyways thanks for the shop I'm sharing with a couple other retired gearhead brothers, and some of their help, this repair is only going to set me back just over $300. $200 for new windshield installed & the cost of paint! Can't complain at all. Will update more when it's finished.
Posted: Tue Sep 19, 2023 4:19 pm
OK ..... here we are in final primer :D
and finally the finished color 8-)
Windshield will go in tomorrow. Finally I'll have this back on the road in a few days :)
Posted: Wed Sep 20, 2023 8:19 am
by coppens1
Your work looks beautiful. Mine just gets worse. Jim
Posted: Thu Sep 21, 2023 6:41 am
Jim. You're just too far away or maybe I'd be able to help you out.
New windshield finally in. Best $300 I ever spent! :D Vibe is now on the lift as I'm going to work on suspension issues while it's in the shop.
Posted: Thu Sep 21, 2023 8:27 am
by coppens1
Wow, looks beautiful. Jim
Posted: Thu Sep 21, 2023 6:13 pm
Thanks Jim. Although not quite appropriate BUT close to this thread, I saw this poor 2003-04 Vibe the other day and couldn't believe the RUST on the roof. Amazingly, there is NO rust around the sunroof frame OR the top of the windshield, like what I experienced. Note: this Vibe still has the original windshield, so it's possible that every time that a windshield is replaced and especially if it's NOT OEM (as in my case) , then potential leakage will always be there!
Posted: Thu Sep 21, 2023 8:54 pm
by jamesmetairie
I remember reading a lot of posts about this subject recently. someone said it appears when they got a new windshield the tech did some scrapping to remove the old black adhesive. In that process the paint was damaged down into bare metal.It then rusted and water would never. The original poster had it mostly on the corner of the passenger side. It is freaky because he would cover that area with a plastic sheet when parked and no water would enter. Then when he drove he said no water would enter. ???
In his post there was photo,s of the repair job to fix it. he had a garage and had to remove the windshield and it was a drawed out process.
Posted: Thu Sep 21, 2023 8:58 pm
by jamesmetairie
sorry guys. I just read the original post and then my 2 cents.
Posted: Fri Sep 22, 2023 9:39 am
by coppens1
It appears to me that there is some kind of design defect that causes the leaking in a car that is otherwise perfect for it's size and design. I will try to contact Pontiac and Toyota about it and ask the question. Jim C
Posted: Sat Dec 23, 2023 8:07 pm
by ckc55
I'm having the same trouble with leaks from the passenger side (this Vibe does not have a moon roof). Were you able to get any information from the manufacturer?
Posted: Sun Dec 24, 2023 10:06 am
by ckc55
A bit more detail about my issue....
My daughter has owned this 2004 Vibe GT since new (163k miles), maintained it well and it still runs great. About two years ago she started to find the outside edge of the passenger seat and the carpet was wet after an overnight rain (she doesn't have a garage so the car lives outside). The car has a solid roof (no moon-roof) and shows no rust around the windshield (which was replaced about 10 years ago). California was in a severe drought when the issue started so it wasn't much of a problem. When the heavy rains started in late 2022 the issue became more important and sometimes when driving in the morning she saw drips coming from the headliner (naturally it was a surprise and she couldn't locate the exact spot because she was driving). The water stain in the headliner is worst over the middle of the front passenger door, about where the grab handle is located. She starting covering the front part of the roof and the top of the windshield with a plastic sheet when rain was forecast overnight, and got through the rainy season in pretty good shape.
However, she has now outgrown the car (husband and two kids) and needs to sell it. I found this thread and our issue seems very similar to that described by coppins1, so I'm obviously hoping for some guidance.
Based on previous messages I spent a few minutes trying to remove the plastic covers on the A and B pillars so as to lower the edge of the headliner, but the covers seemed very tight and I fear they won't go back on properly.
Thanks in advance for any suggestions!
