Sunroof Noise
Posted: Wed Dec 23, 2015 7:35 am
by saweetlou
I can hear a air leak when Im doing highway speeds so much so that I have to close the cover to drown it out. Has anyone had this problem before. Its not leaking any water at least that I can see.
Re: Sunroof Noise
Posted: Sat Jan 02, 2016 5:38 pm
Negative here .... BUT we have two 2009 Vibe GT's with sunroofs. What year are you talking about? More info please.
Re: Sunroof Noise
Posted: Sun Jan 03, 2016 7:10 am
by vibenvy
The screws that hold the sunroof glass to the frame may be loose causing the air leak. There is one in each corner (4 total) of the sunroof glass. They should be torx screws.
Re: Sunroof Noise
Posted: Sun Jan 03, 2016 6:23 pm
by vibrologist
My glass was not completely flush with the metal roof. I loosened a bolt or 2 and adjusted the glass. Check yours and inspect the rubber surround closely.
