03 Cluster
Posted: Mon Nov 16, 2015 11:26 pm
by Pings
So i've seen and read some of the posts on swapping out clusters in 03 to an 04, unfortunately the pictures that are with the guides are no longer available and no one wants to do it in this area for under $300. So That being said, are the LED's behind the 03 cluster faces red or white? If so, are the faces of the tachometers interchangeable? For example if i remove the 04 speedometer face and put it on the 03 will it come out as red? I figured if so this would be a much cheaper, easier way of getting that 04 cluster look in the vehicle.
Re: 03 Cluster
Posted: Tue Nov 17, 2015 11:18 am
by RDUNick
Check this out. http://webpages.charter.net/dodadew/Matrix/ledcluster/. It's for an '03 Matrix but I believe they are the same as the Vibe.
Re: 03 Cluster
Posted: Tue Nov 17, 2015 4:49 pm
by Pings
RDUNick wrote:Check this out. http://webpages.charter.net/dodadew/Matrix/ledcluster/. It's for an '03 Matrix but I believe they are the same as the Vibe.
Thanks! Needed to know if it was red or not. I guess my gauge swap isnt going to be as easy as i wanted it to be.
Re: 03 Cluster
Posted: Sat Dec 19, 2015 8:47 pm
by BenWA
You could get a junkyard one to mod ahead of time and swap in so your car won't be down so long.
