P0171b?
Posted: Thu Nov 12, 2015 8:09 am
by 21Rouge
I had a solid yellow engine light come on earlier this week (2005 Vibe MT)
I left it with my independent mechanic and he emailed me that the code shown is P0171b system lean bank.
(He says the idle is at 1200 rpm).
Can someone tell me what specifically what this code refers to specifically?
Re: P0171b?
Posted: Thu Nov 12, 2015 8:18 am
by gtv237
It means that either unmetered air is entering the engine or there is a lack a of fuel.
Re: P0171b?
Posted: Thu Nov 12, 2015 8:25 am
by 21Rouge
gtv237 wrote:It means that either unmetered air is entering the engine or there is a lack a of fuel.
Thanks for the quick reply 'gtv'.
In the little that I drove it after seeing the light there were no driving issues at all.
What would you suggest one check re either of these seemingly unrelated issues?
(What is the usual idle for an 05 Vibe?)
Re: P0171b?
Posted: Thu Nov 12, 2015 12:40 pm
by vibrologist
warm idle should be near 800 rpm, maybe as low as 750 rpm. My automatic does 800 when I shift into N.
First thing to do when the lean code appears: look for vacuum leaks anywhere between the MAF sensor and the cylinder head. Also go back on all the vacuum hoses, and don't forget the PCV system. Even the oil filler cap could be a source of vacuum leaks.
If there are no vacuum leaks, check the fuel pressure and injectors.
Check the DBW system.
Re: P0171b?
Posted: Thu Nov 12, 2015 12:52 pm
by 21Rouge
vibrologist wrote:warm idle should be near 800 rpm, maybe as low as 750 rpm. My automatic does 800 when I shift into N.
I guess it makes no difference manual vs automatic?
vibrologist wrote:If there are no vacuum leaks, check the fuel pressure and injectors.
Can be a pain solving a high idle
Re: P0171b?
Posted: Thu Nov 12, 2015 2:49 pm
by circuitsmith
Perhaps leaky intake manifold gasket.
Re: P0171b?
Posted: Thu Nov 12, 2015 2:50 pm
by 21Rouge
Does the 05 Vibe have an air intake temperature sensor or is it incorporated with the maf sensor?
Re: P0171b?
Posted: Thu Nov 12, 2015 2:53 pm
by 21Rouge
circuitsmith wrote:Perhaps leaky intake manifold gasket.
The mechanic replaced just today the intake manifold gasket (hard and cracked and leaking oil)
Re: P0171b?
Posted: Fri Nov 13, 2015 12:38 pm
by vibrologist
21Rouge wrote:circuitsmith wrote:Perhaps leaky intake manifold gasket.
There you go! I replaced mine even before I had a CEL on. It was idling rough when warming up and ran smooth when warm. That does not mean that I am smarter than OBDII
, I had experienced this with a Ford Windstar before.
Re: P0171b?
Posted: Fri Nov 13, 2015 4:12 pm
by Salsa Guy
The 05 were not really affect by a leaky manifold gaskets 03-04 were. You have a 10 y/o car and not sure what inspections and maintenance you have done but start with hoses and clamps around the intake and TB. Use a Carb Cleaner to isolate the issue.
Re: P0171b?
Posted: Fri Nov 13, 2015 6:21 pm
could it also be caused by a dirty MAF sensor?, at least that's easy to clean
Re: P0171b?
Posted: Sat Nov 14, 2015 4:04 am
by 21Rouge
Thanks for the help everyone.
Replacement of the MAF sensor seems to have resulted in a lower idle...about 900 rpm (colder days).
Re: P0171b?
Posted: Sat Nov 14, 2015 7:44 am
by vibrologist
Salsa Guy wrote:The 05 were not really affect by a leaky manifold gaskets 03-04 were. You have a 10 y/o car and not sure what inspections and maintenance you have done but start with hoses and clamps around the intake and TB. Use a Carb Cleaner to isolate the issue.
Maybe they were not affected as much but they sure start failing now. The problem is the oil that get sucked up through the PCV system. It destroys the rubber over time. It is a really easy diy project and the gaskets are cheap to buy.
Re: P0171b?
Posted: Mon Nov 16, 2015 7:25 am
by circuitsmith
My 2006 had the black gasket, which I changed after 47k miles and 8 years.
No symptoms, but was pretty hard and was deformed in one spot.
