Summary of normal rusty areas?
Posted: Tue Nov 03, 2015 5:14 pm
As in, is there one or is there any consensus on what is normal rust for a 2005 Vibe? Base model here.
I got mine two years ago, finally got around to taking care of the outside, chasing down rust.
So far I have found rust under the black front door sill plates, just from trapped salt I think, rust under the rear window along the gasket and under the gasket and rust streaks coming from both rear door handles. I'll have a look at those tomorrow, take advantage of our great weather in Ontario.
I pulled the rear license plate and found some rust around the plate bolt holes also.
I have rusty spots from stone chips that were never dealt with, normal wear and tear there.
Other than that, are there any known areas that I should be looking at? I've been under the car and it looks great, flushed water through most every hole I could find in any frame member and didn't get any dirt or salt coming out so I assume it's all good there.
Oh, I did pull back the front inner fender liners at the rear bottom and found a nice bunch of wet leaves and some sand
in there. Flushed the hell outta the area and it looks good now.
Cheers
Peter
Cheers
Peter
