best brand treatments?
Posted: Mon Oct 26, 2015 10:23 am
by jeff_j1701
Hello,
I'm just wondering what everyone thinks is the best brand of treatments/additives out there.
Fuel system cleaner, fuel injector cleaner, gas treatment, etc.
I have an '07 Vibe and I've used Lucas and STP. Mainly STP because of the price. :)
Re: best brand treatments?
Posted: Mon Oct 26, 2015 10:28 am
by kumquat
Modern fuels are very cleansing as it is. There's no need for any additives.
Posted: Mon Oct 26, 2015 10:35 am
by vibrologist
jeff_j1701 wrote:Hello,
you know you are wasting your money? http://www.bobistheoilguy.com/motor-oil-101/
Posted: Mon Oct 26, 2015 4:05 pm
by vibenvy
I add a bottle of Techron to a full tank of gas for each of our Vibes every 5000 miles when I change the oil.
Posted: Tue Oct 27, 2015 9:25 am
by ehoff121
vibenvy wrote:I add a bottle of Techron to a full tank of gas for each of our Vibes every 5000 miles when I change the oil.
+1
Posted: Tue Oct 27, 2015 11:35 am
by Derf
Usually add something labeled to neutralize water collection by ethanol. Agree most fuels now have better additive package, but they go only so far preventing the fuel system collecting moisture.
Posted: Tue Oct 27, 2015 4:29 pm
by vibrologist
Derf wrote:Usually add something labeled to neutralize water collection by ethanol. Agree most fuels now have better additive package, but they go only so far preventing the fuel system collecting moisture.
Even that is pretty much a thing of the past. Pure gasoline is oil like and will not mix with water. Ethanol mixes with water. In my area it is getting harder and harder to find ethanol-free gasoline and it is much more expensive the the ethanol blended gas. Therefore I use ethanol blend with about 10% ethanol. That eliminates any moisture problems.
Posted: Tue Oct 27, 2015 8:53 pm
by ctgottapee
Techron is really all that is useful for gas
I use some brand additives, satisfied with the kicks of using even if it doesn't work.
-Seafom for intake cleaning; making smoke is fun (my inner businessman says I would just put something in the product that guaranteed it would blue smoke no matter what when used in this manner)
-LiquiMoly I like the engine cleaner (my inner businessman says I would just put something in the product that guaranteed it would turn oil dark black when it contacted it)
-AMSOIL oils, can't really justify it
-Lugeguard if it's transmission related
-Oil analysis labs - if you really want to have an idea of what is going on in the engine,trans,cooling; have it analyzed
Posted: Wed Oct 28, 2015 1:14 pm
by Derf
vibrologist wrote: Even that is pretty much a thing of the past. Pure gasoline is oil like and will not mix with water. Ethanol mixes with water
Agree, before water would collect in the bottom of the fuel tank. Ethanol however, absorbs water causing phase separation in the fuel, you end up with gasoline ethanol blend on top and a water ethanol blend on the bottom. This causes less issues than pure gasoline. Its the concentration of water that could be an issue. Especially in negative temperatures when you drive less allowing phase separation to accumulate.
