Now i read on forums that the stock wires suck. And you lose a lot of voltage. Also that voltage drop to headlights is non linear. Meaning a 1 volt drop will output a lot less lumens (about 25% less aparently!!)
I tested it and the voltage at the battery withengine running is 14.2. Voltage at the bulb was 13.1. That does seem like quite a lot of voltage loss. I was thinking of testing one directly connected to the battery to see if the 1.1 volt really will make a good difference. And if it does i would make a relay system for the lows/highs and fogs.
Has anybody tested this ?
Have any of you found a way to make the lighting system better ? I would like to stay legal. So i dont want to go ebay h.i.d conversion. But i did find some bulbs that fit in oem with better wattage (ex: i replaced the stock 9006 fog bulbs with 9012 wich is 10 more watts, it made a noticeable difference)
I live in canada and work night shift. So about 75% of my driving is in the dark....
